  #11 (permalink)
Old 10-15-2002
Sailmc is on a distinguished road
Replacing Roller Furling
WHOOSH, Maybe you ought to go back to your hank on sails. There are likely and unlikely failures. Halyard wrap falls squarely into the unlikely catagory if the furler is properly installed. I really can''t think of a scenario that would would cause this to suddenly and inexplicably happen. Can you?
  #12 (permalink)
Old 10-16-2002
RobGallagher is on a distinguished road
Halyard wrap can happen after a sail change.
If you forget to forget to tighten the jib halyard, then try and furl the sail... Don''t ask me how I know
  #13 (permalink)
Old 10-16-2002
WHOOSH is on a distinguished road
As Rob states, that''s one way to get in trouble when over-torquing the furling line. Another is if the furling line is fouled at the bottom drum because the lead block slipped; happened on 2 boats I know in the last year plus.
The notion that once something is installed correctly, it no longer can present problems is a foreign one to me.
Jack
Mariner Roller Furling jkoutras Gear & Maintenance 8 02-13-2012 10:26 AM
Hyde Roller Furling gaurre3 Gear & Maintenance 13 08-01-2010 08:16 PM
Mechanical difference between roller furling and reefing? duffer1960 Gear & Maintenance 6 10-26-2009 09:46 AM
Roller Furling Dan_T Gear & Maintenance 6 11-02-2001 11:14 AM
Roller Furling stewpee Gear & Maintenance 1 05-30-2001 04:59 PM
