Portable Generator - Page 2 - SailNet Community
post #11 of 14 Old 02-24-2009
celenoglu's Avatar
Most generators (specially Chineese) are manufactured for AC (110V) generation. They can supply 12 V for charging purposes but the output is generally low. Make sure to look for a good unit that has a high current output for 12 V.
It is a better idea to usesolar panels + wind power for charging. They are more silent, does not need gasoline and work 24 hours.
Some makes of wind generators are too noisy. Used a three blade one with blades narrowing on the tips. In fact I stopped it due to extra noise.
I alsoused a five blade one with blades not narrowing. It was very silent. You cannot even know if it is working.
celenoglu is online now
post #12 of 14 Old 02-24-2009
If anyone is consudering using a small generator of any ilk, it would be a good idea to consider what Xantrex has to say about it.
Howard Keiper
Berkeley
thekeip is offline
post #13 of 14 Old 02-24-2009
Barking Dog
I have a 2000 watt Honda and only run it when absolutely needed. The fumes are crazy and I am sure that carbon monoxide comes well before the fumes. I tried putting it on the bow on the stern and in the digny (10 feet back from the boat).
Craig
KindOfBlue is offline
post #14 of 14 Old 02-24-2009
Craig ?!
You mean, you didn't read the Special Honda Marine Manual, the part that says the genset should be hoisted to the masthead immediately after starting?
hellosailor is offline
portable generator on 30ft sailboat ? Volkhard Gear & Maintenance 28 04-02-2010 12:34 PM
Help costing a generator and lots of generator questions... labatt Gear & Maintenance 10 10-16-2008 02:01 AM
Portable Generator vs Genset dougshipl Gear & Maintenance 109 06-07-2008 01:36 PM
New Portable Generator bushrat Gear & Maintenance 22 04-01-2008 06:20 PM
Generator battery charging..... avazquez Gear & Maintenance 1 09-06-2007 10:19 AM
