02-24-2009
It would help if you said what the mainsheet setup on your boat was... it could be two triple sheaves for a 6:1, two double sheaves for a 4:1, three single blocks and a triple at the traveler for 6:1, etc. More information is generally better than less or Garbage IN ==> Garbage OUT as they say in the comp sci classes.
Harken has some good drawings. For instance, here's a 6:1 mainsheet using two triple blocks.
