Small hole completly aft at waterline - Page 2 - SailNet Community
post #11 of 25 Old 02-26-2009
Just a thought, which Beneteau should be able to confirm. The holes are evenly spaced at the point where the rubrail attaches, and by inference where the hull and deck/stern join together. I would guess that the holes were there intentionally for some bolts, screws, jig parts for holding the the hull and deck/stern together tightly while the joint was completed (curing time for fiberglass or adhesive that joins the two fiberglass parts). There was probably an oversight in the production of your boat in that these temporary holes were not sealed and glassed over. Also, I think to resolve the problem, you would seal the holes and glass over the holes. When Beneteu sees exactly what you are talking about, they should recognize the situation imediately. Send them some still photos from the video so they can see it exactly, including the uniform hole spacing. Good luck.
NCC320 is offline
post #12 of 25 Old 02-26-2009
Are you sure the holes aren't old attachment points for fastners? Has a tank of some sort been removed?
sailhog is offline
post #13 of 25 Old 02-26-2009
Moderator
JohnRPollard's Avatar
Bene,
My hunch is similar to NCC's above. It appears the screws that hold the rubrail in place were too long and penetrated completely through the laminate, creating a path for water to enter the boat as it trickled to the low point of the rubrail. The lingering question is whether these fasteners also serve to mechanically bind the deck to hull.
To save money, most production boats with swim scoop/step arrangements have those features incorporated into the deck mould. So when the "deck" gets attached to the hull, part of that attachment occurs down at or near the waterline at the bottom of the swim-scoop stern. (For this reason, many traditionalists prefer designs where the transom/stern is part of the hull mould, so that the hull-to-deck joint does not extend down to the waterline. But it's more expensive to do it this way.)
Often with these designs, a rubber rubrail gets put over the (unsightly) seam between the hull and deck. Sometimes the fasteners serve double duty and are part of the design to hold the hull and deck together. Not always, though. And It could be that those holes are caused by the hidden hull/deck fasteners, not the rubrail fasteners. Some builders merely tap their hull/deck fasteners into the laminate without actually through-bolting them ( ), and rely more on the chemical bond of adhesives. Some others tap them into an embedded aluminum plate.
Beneteau should advise you on this and suggest an appropriate remedy. (One serious concern would be if there is any coring in that material, but I doubt it.) I would not ignore it though. Keep us posted.
JohnRPollard is offline
post #14 of 25 Old 02-27-2009 Thread Starter
Glad I found Sailnet
Bene505's Avatar
The holes go on the whole extent of the stern, IIRC. They aren't attachment points.
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #15 of 25 Old 02-27-2009
If they were for the hull-deck join or the rubrail, they might go the whole extent of the stern.
sailingdog is offline
post #16 of 25 Old 02-27-2009 Thread Starter
Bene505's Avatar
I just got off the phone with Ward at Beneteau USA. He took the time to look at this thread and even downloaded the video to look at the series of holes.
The holes were drilled for the screws that hold the rub rail (bumper) in place.
He recommended removing the bumper, unscrewing the screws that are leaking and resealing them by squirting 3M5200 (with a caulking gun) right into the hole and then screwing the screws back in.
I love the positive attitude they have there. I asked if this was the strangest question he got all week. He said no, this is one of the good ones, it's coming from someone who is trying to take care of their boat. These guys must love sailboats.
Anyway, I got another contact at Beneteau, I'm sure I'll be asking him more questions - intelligent or otherwise. Thanks everyone for the input.
(And I'm thinking maybe I should fill-in the holes from the inside. It couldn't hurt, other than squeezing into the tight space and breathing epoxy fumes, right? But it may be difficult if I use a lot of that 3M5200.)
Bene505 is offline
post #17 of 25 Old 02-27-2009
I wouldn't use 5200 for that... I'd recommend using 4200 or something that you'd be able remove in the future.
post #18 of 25 Old 02-28-2009
Wayne25's Avatar
Its great you got the reason for the hole answered. Must be nice to have the factory still in business for questions like that :-)
I know they recommended 5200, but if I was asking the question, I would of asked why not pot the holes with thickened epoxy as is recommended for most hull and deck holes? Maybe he is responding as he would to a typical owner that doesn't know what potting a hole means, but can handle a caulking gun. Or, that's what they used at the factory in the holes during construction.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #19 of 25 Old 02-28-2009
Wayne—
The fasteners still go through the holes is my guess...you wouldn't want to fill the hole with epoxy if you might have to remove the fasteners in the future.
post #20 of 25 Old 03-02-2009 Thread Starter
Bene505's Avatar
SD,
To Wayne's question, what about filling with epoxy AFTER the new screws are in place? Would that mean that one couldn't remove the new screws in the future? (If yes, then what about putting something on the screws so they don't stick to the epoxy?)
Bene505 is offline
Can a Bristol 32 Circumnavigate? mmcdan Boat Review and Purchase Forum 55 02-07-2017 08:43 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
the perfect 20'' cruising boat? jbarros Boat Review and Purchase Forum 14 04-18-2004 06:45 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
