Aluminum Tank Inspection Port - SailNet Community
post #1 of 3 Old 02-25-2009 Thread Starter
Does anyone have a suggestion for covering an inspection port in the top of an aluminum tank. I checked out the ones from Seabuilt......alot of cash. Any other suggestions? How about applying a good coat of 5200 to the tank and screwing on a new piece of aluminum, sound crazy. Don't need to remove again, atleast not in the next 10 to 20 years I hope. Thanks for any help.
"The hardest way is usually the easiest way."
"All I have to do is............."
cruiserdave is offline
post #2 of 3 Old 02-26-2009
Omatako's Avatar
Hey Dave
Here's what I have done with great success in the past:
  • Make up a cover that will close the hole with a border of about 20mm from aluminium of suitable thickness (probably a little thicker than the skin of the tank
  • Make up a ring the same size as the cover with the hole in the middle the same size as the hole in the tank but make this out of thicker again, say 3mm ali.
  • Drill the ring with the number of fasteners you plan on using. I would recommend using 5mm Monel pop rivets but if you're going to use self tapping screws drill the tank and the cover for the screws to fall thru and the ring for the screw to tap into.
  • Use the ring as a template and drill the tank and the cover plate the same. A good idea at this time is to mark the three sets of drilling so that they're easy to get lined up later.
  • Cut the ring in half.
  • After coating each side with a suitable fuel resistant gasket cement (don't know whats available in your neck fo the woods, I use Permaseal No. 2 non hardening) put the halves inside the tank and temporarily fasten them until the gasket cement holds them in place.
  • Once both are stuck to the inside of the tank install the cover (using gasket cement) and rivet/screw to the plates inside.
  • It is strong, it'll not leak and it won't distort the tank.
Hope this helps.
Arthur C. Clarke
Omatako is offline
post #3 of 3 Old 02-26-2009
I wouldn't use pop rivets on a fuel tank, as IIRC, pop rivets have a small hole through them normally for the mandrel used to close them, and as such are not vapor tight.
sailingdog is offline
Add Inspection Port to Existing Tank mlitzkow Gear & Maintenance 5 05-17-2016 11:12 AM
Aluminum fuel tank - installing an inspection plate rikhall Gear & Maintenance 7 02-24-2009 03:29 PM
FS: Tank inspection port PaulSears Gear & Maintenance 1 01-12-2009 08:09 AM
inspection port for fuel tank ambianceack Gear & Maintenance 3 01-11-2009 10:06 PM
Fuel Tank Inspection Port MrBreeze Gear & Maintenance 0 04-24-2007 01:45 PM
