Perkins 4108 power problem - Page 2 - SailNet Community
post #11 of 17 Old 02-27-2009
timebandit's Avatar
I have read the problem and all you have done to fix it but I have not read how the problem started.
Were you just crusing and all of a sudden you lost power?
Input, need input.
Originally Posted by FiandDog View Post
Hi CarolinaB and thanks for your advice. I've confirmed with the engineer and he's checked the throttle connection so unfortunately we have to rule that out also. The only thing left is a new fuel pump - being connected as we speak - so we have our fingers crossed (as desparate folk do!).
Many thanks for trying to help, F
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #12 of 17 Old 02-27-2009 Thread Starter
The engine was overhauled prior to our departure from the UK last June. We have had no problems since then until the last short passage we did. Thanks for your interest
FiandDog is offline
post #13 of 17 Old 02-27-2009
timebandit's Avatar
Did the power just slowly decrease or go all of a suden?
Rick
Mac 25
Copernicus
Southern California
post #14 of 17 Old 02-27-2009 Thread Starter
The engine was on tickover and it wasn't til we asked for power we realised it wasn't there so we're not really sure how sudden it was.
FiandDog is offline
post #15 of 17 Old 02-27-2009
timebandit's Avatar
Is the oil level high indicating that the diphram in the fuel pump may be punctured?
A vaccumn gage on the intake side will check that sides valve and a pressure gage on the output side should be some where around 5 psi.
Rick
Mac 25
Copernicus
Southern California
post #16 of 17 Old 03-01-2009 Thread Starter
Thank you everyone for your kind assistance with this problem. After a week of investigations, replacements, adjustments etc it has been found that the throttle linkage had slipped (we asked this to be checked in the first instance!) and therefore, we hope, the problem is now resolved.
FiandDog is offline
post #17 of 17 Old 03-02-2009
timebandit's Avatar
Thanks for the the report.
It's allways good to find out what the problem was.
It is to bad such a simple fix cost so much money.
Rick
Mac 25
Copernicus
Southern California
WARNING..shore power ON, engine ON is a NO-NO Giulietta Gear & Maintenance 20 01-14-2008 07:12 AM
Shore power for skiffs sailboy21 Gear & Maintenance 4 12-25-2007 04:52 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 09:00 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 06:08 AM
Dockside Power Tom Wood Gear and Maintenance Articles 0 02-07-2002 08:00 PM
