02-27-2009
Just curious, why did you go with a Flexcharge PV7D. It would make far more sense to go with a single bank charge controller and use an echo charger to deal with the starting bank.
An ACR won't interfere with a charger doing a battery conditioning cycle generally, since it is just a relay. An echo charger will.
Again, I wouldn't bother going to the expense of getting a two-bank charger, since it would make more sense to use an echo charger with a single bank charger.
IMHO, you're making the system overly complex, and spending more money than you have to. There is no need to treat the house bank as two separate batteries, and very little advantage in doing so.
