Old 02-27-2009
thisisus is on a distinguished road
Islander 32 Running lines to the back
Looking for Islander 32 owners who may have ran lines aft. Seeing how you laid it out. Wanting to run main and reefing lines aft. Has external halyards. Mark II version. Or others ideas how they got their lines back. Trying to decide between single turn blocks, some type of mast plates to add blocks. Any ideas. Thanks
Thisisus
Islander 32
Mobile AL
Old 02-28-2009
While I don't have an Islander 32, I have done this project. I would highly recommend using some sort of mast plates, especially if the mast is deck stepped and you can modify the deck mast step with a collar or add plates to it as I did.
Also, I highly recommend using a two-line reefing system, rather than a one-line, even though it requires a bit more hardware. The reason for this is that you get better sail shape control out of a two line reefing system than you do with single line reefing.
Old 02-28-2009
This one is a keel stepped mast, but adding a collar would still be possible. Our last one had a deck stepped and we had to make a new step. When we did we add some tabs off the front and back to attach blocks. Worked great. Also agree with the two line reef. We tried a single on this one and with all the loads was always difficult to get right. Did the two line and was actually faster once you practiced. Also like you said the sail shape was much better.
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
Life in the fast lane, well for one day at least... Lancer28 Learning to Sail 8 11-27-2007 10:36 PM
The Long Way Back, Part Five James Baldwin Cruising Articles 0 05-27-2004 08:00 PM
BVI trip report 8-18 Jul 03 (long) DuaneIsing Chartering 5 08-06-2003 06:15 AM
Thoughts on Running Aground Mark Matthews Racing Articles 0 08-06-2001 08:00 PM
