Like Tree8Likes
Old 02-28-2009
pvanv1's Avatar
Hinterhoeller HR28
pvanv1 is on a distinguished road
Question Red Over Green
The USCG refers to various "occupation Lights" for commercial vessels. Categories include RAM (restricted in ability to maneuver), NUC (not under command), Pilot, etc., etc.
They also allow a Red Over Green top-of-mast lamp for a sailing vessel. I have never seen this displayed on the Great lakes, and don't know where one would buy such a unit.
Maybe the Masthead TriColor is more popular, but I know that if a TriColor is lit, the USCG requires that the regular sidelights and sternlight must not be displayed simultaneously. However, they do allow a red-over-green to be on at the same time. So you can legally run the red-over-green Occupation lamp at the same time as the regular sidelights and sternlight.
In the interest of being seen at night (especially when heeling, or the sidelights are obscured by a large Genoa), and particularly when racing, or when on large seas, or near shipping lanes, the red-over-green occupation light seems prudent.
Does anyone have a source where these can be purchased?
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
Old 02-28-2009
Most people don't use the red over green since they have to have a meter or so separating the two lights. It also requires running two more bulbs... with the associated electrical drain. If visibility is an issue, why not just use a masthead tricolor?
Old 02-28-2009
pvanv1's Avatar
Hinterhoeller HR28
Valid points. I wasn't aware of the 1-meter separation requirement. I wonder if I can verify the exact requirements easily?
My reasons for considering the Occupation lamp are:
If running LED's, power drain is a non-issue.
The red-over-green is legal on all sizes of yachts -- the tricolor is not.
More lights means more possibility of being seen.
Paul Van Voorhees
Buffalo, NY USA
Old 02-28-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
Paul,
Rule 25(c) allows any sailing vessel to carry, in addition to sidelights and sternlight, red over green all-round lights.
Annex I para 2 specifies the vertical positioning and spacing of lights. On a vessel less than 20 meters vertical lights must be spaced at least 1 meter and the lower light must be at least 2 meters above the deck.
Bill
BTW, the tricolor is legal for vessels under 20m in length. Is yours larger?
B.
Old 02-28-2009
pvanv1's Avatar
Hinterhoeller HR28
Bill,
No, my current vessel is in the "under 12 meter" category. But some of the boats I have delivered are indeed too long to legally run a tricolor.
Too bad that they require a full meter of spacing; That would get to be awfully clunky on a 30 footer's mast -- both windage and weight aloft would be real issues.
Paul Van Voorhees
Buffalo, NY USA
Old 02-28-2009
JohnRPollard's Avatar
Moderator
We've had more than a few discussions about the "red-over-green sailing machine" light configuration. Most recently a week or two ago:
http://www.sailnet.com/forums/genera...g-vessels.html
As I mentioned in that thread, I have seen them implemented with pairs of 180 degree lights on each side of the mast. It is fairly straightforward.
Old 03-02-2009
Unfortunately, that then requires FOUR Bulbs and fixtures, and is a pretty big electrical draw, especially on a smaller boat.
Old 03-02-2009
Moderator
It could be implemented with low-draw L.E.D.s, along with converting the deck lights to same. It would probably be less total power draw than with the typical deck-level incandescents. But I'm speculating a bit. Has anyone done the math on this?
Even if the power draw were marginally greater, I still feel it's a better solution than the either/or alternative. You'd still have the option of running with just deck lights to conserve power if necessary.
Old 03-02-2009
True... LEDs change a lot of things, but finding LEDs that are USCG certified for this use is a problem.
Old 03-02-2009
Moderator
Probably the best/most efficient way to implement it would be with a single red at the top of the mast, and a pair of greens on either side of the mast 3-5 feet below the masthead. Gets rid of one bulb, anyway, as well as a bit of wiring. The red could be capped with the all-round anchor light, too.
Any vendors listening?
LEDs afloat GoodOldBoat Gear and Maintenance Articles 18 12 Hours Ago 03:15 PM
Green driveshaft- how do I upload the photo? justonemoreproject Gear & Maintenance 11 11-16-2008 06:57 AM
Extra green time for smooth sailing over new bridge: Extra green light time sought Extra green light time sought over (Asbury Park Press) NewsReader News Feeds 0 04-23-2006 05:15 AM
Is the Red Sea Red? Michael Zezima Seamanship Articles 0 02-03-2003 07:00 PM
The Green Flash Dan Dickison Cruising Articles 0 02-28-2002 07:00 PM
