Catalina 22 mast light disconnect question - Page 2 - SailNet Community
post #11 of 13 Old 03-01-2009
saildork's Avatar
Andy, it just occurred to me that there might be a set screw or 2 on the housing of the deck connector. If there are, unscrew them with a small screw driver. That might allow the housing to lift off the deck easily. Also, since you have only the one connector to port of the maststep, you can use the 4-conductor setup you suggested earlier to replace the 2-conductor setup you have now.
Once you have removed the deck connector, drill thru the headliner from above and pull the 2 existing wires down into the cabin. You can then hook up a couple switches at or near the compression post to operate masthead, steaming and deck lights. You will feed 4 wires (1 ground and 3 hot) up thru the hole and into the female deck connector.
Catalina Direct offers a wiring harness for the lights, if you don't want to do the wiring yourself. Check out their website or consult the handbook that they provide. Let me know how it goes.
Pat
p.s. If your existing wires are corroded, don't use them. Just run wire back to the power panel as we discussed above.
Pat
Sailing isn't a matter of life and death. It's much more important than that!
saildork is offline
post #12 of 13 Old 03-03-2009 Thread Starter
Thank you especially Pat.
Thank you very much it will be a while before I complete this task but I will let you know, Andy
andyjen is offline
post #13 of 13 Old 03-04-2009
I replaced that on my C22 2 years ago. Although my problem started with the fixed assembly being rotted and you couldn't fix the wires with the set screw so I never got a good connection. I remember replacing the unit with a 4 pole but just using the existing wire ends. I did rewire the mast using the diagram in the users group list which showed mounting a two way switch on the mast with up lighting one and down lighting the other. Simple and easy to reach with the pop top up or down.
geraldartman is offline
mast head light caliber LRC 2000 hasuehounds Caliber 1 03-08-2009 11:03 PM
tuning rig janders Caliber 5 02-14-2009 01:09 PM
Oday 22/23 vs 25/26 firefitn Boat Review and Purchase Forum 15 12-03-2008 09:42 AM
Mast Repair Question montenido Gear & Maintenance 3 05-30-2008 01:03 PM
Anchor Light - Newbie Question Fasteddy General Discussion (sailing related) 1 05-20-2002 11:50 AM
