-   -   Stainless Chain Question (http://www.sailnet.com/forums/gear-maintenance/5201-stainless-chain-question.html)
grey99 10-14-2002 07:57 AM
Somone gave me a nice length of stainless chain and I am thinking of using it on the anchor, which is galvanized. I have a nagging thought that this might not be a good idea because of the dissimilar metals problem weakening the stainless -- is this true? Any comments appreciated. Thanks.
windship 10-14-2002 08:39 AM
grey99,
Good morning.
What you say about dissimilar metals is true. I don''t think I would use it because it will probably cause the zinc coating on your anchor to sacrifice.
I think I would only use SS chain with a SS anchor.
Dennis
Jeff_H 10-14-2002 07:18 PM
The way that most anchors are used (i.e. on deck far more than they are in the water) the stainless steel chain should be fine. If you have any concerns about dissimilar metals I would put a piece of plastic hose around the shackle pin and sides of the shackle to isolate the chain from the galvanized steel. I would not use the stainless steel chain for a permanent anchor or if you exclusively anchor your boat rather than occasionally anchor your boat.
asailor 10-15-2002 09:09 AM
Im not quite sure why you would want to piece together 2 different chains of any type. Anyway, the shackle is going to be your weakest link. Therefore, i would use a stainless steal shackle, as there breaking point is much stronger than others.
grey99 10-15-2002 04:34 PM
Hi-- And thanks for the advice. I think I am going to find another use for this beautiful stainless steel chain, or if I do go with hooking it up (cause my anchor does stay up mostly) your suggestions on how to do it safely are most useful. This board is great! Thanks!
