Old 03-02-2009
Quickstep192 is on a distinguished road
Outboard Propeller Question
I read that the propellers that come on outboard motors used as sailboat kickers aren't propped correctly for displacement boats. Does anyone know where to get different pitch propellers for a Honda 8hp outboard and what the proper pitch would be for a 4,000 pound 24' sailboat?
Old 03-03-2009
You can probably get a few different pitches for that at Piranha.com, which sells the composite Piranha propellor. I'd try a 9.5" x 5 or 9.5" x 7 to start with.
Old 03-03-2009
pvanv1's Avatar
Hinterhoeller HR28
pvanv1 is on a distinguished road
Lightbulb
I have found that the Solas High Thrust props work well in these instances. I have one on my 8,000 pound HR28, and the 9.8 Nissan pushes her better than the old OMC 15 (with 5" pitch "sail" prop) did. That's a motor size down, and better thrust.
But wading through their prop finder on the website can test your patience...
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
Outboard Mount and the transom of a Cal 20 lostcoast Cal 5 11-12-2008 04:28 PM
Motor: DIY or Pay up; that is the question canoeman256 General Discussion (sailing related) 11 10-11-2008 05:16 PM
Gas Outboard Recommendations or should I keep the Trolling Motor cristamd Gear & Maintenance 14 08-30-2008 02:20 PM
Repowering with an outboard? MattGardner Gear & Maintenance 14 08-19-2008 05:03 AM
Small outboard motor question for the maintenance experts. Northbeach Gear & Maintenance 7 07-19-2008 12:48 AM
