Old 03-04-2009
northstarjim is on a distinguished road
atomic 4 damage?
I went to check my boat today (it is on the cradle) and was stunned to see about 12 inches of water and ice inside. There has been a lot of snow and rain this year and I haven't been able to check it for a few weeks. The water level was approx 2 inches above the oil fill cap, so I know water will have entered the case. I think it was just below the alternator. It was half way up the coil. The starter was submerged. I am feeling sick about it. How much damage is likely? Is it easy to flush water from the oilcase? What components are relatively watertight?
Old 03-04-2009
bluwateronly's Avatar
bluwateronly is on a distinguished road
I hope you drained the oil and put some wd40 in the sparkplug holes. Dont let it sit it could freeze up. I am sure others with more experience will give you exact info on what to do but start soon.
Old 03-04-2009
not Sully or Dandelion
MorganPaul is on a distinguished road
Sorry to here that man. I have an old Atomic 4 myself.
You might be able to get answers at the Moyers web site.
Moyer Marine Atomic 4 Community - Powered by vBulletin
Old 03-04-2009
The real question is did water freeze inside the engine. Water expands about 10% when it freezes and if it did, the damage could be pretty bad.
Old 03-04-2009
Irrationally Exuberant
arf145 is on a distinguished road
Man, sorry about that Jim. While you wait for the Atomic 4 experts to weigh in, I would just second what bluwateronly said--definitely drain the oil. You'll see if you've got water in there. I would also pull the plugs and try to test for water in the cylinders, maybe even try to suck out anything in there. The WD40 sounds good.
Did the water get over the air filter?
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 03-04-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
The situation sounds bad but do not give up hope.
We had a flood in our cabin 5 years ago that got water in the engine oil. I won't divulge the reason for a the flood while on a mooring but suffice it to say it was salt water and nearly 6" above the cabin sole (floor). This was high enough for some water to get into the dipstick hole. Our engine wasn't completely flooded, plus it was summer so no freezing.
After removing the water from the cabin the engine started right up. Later, we checked the oil and found a milky color. Uh-oh! After a call to Don Moyer (see link previously posted) I went and changed the oil in the engine 3 times and each change came out clearer and clearer. Last oil change I put in Rotella T SAE 30 but for the quick oil changes I used cheaper oil.
Our engine is over 40 years old and is still ticking. I hope you have similar results.
Old 03-05-2009
patrickrea's Avatar
patrickrea is on a distinguished road
Where is the boat located?
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
Old 03-05-2009
scottyt is on a distinguished road
drain the oil, fill it up including the cylinders with oil. turn it over using either the crank start or a crow bar, just a little per day. after a few rotations drain and fill it with oil and marvel mystery oil. let it sit till spring, but you need to make sure it full to the top.
spring time drain oil put a quart of marvel and normal oil in then start it, let it get to temp, shut it off, drain oil fill, run it for a few days change oil.
that is the directions i got from moyer when i fixed a flooded and rusted solid engine, it took days to get it to go thru a full rotation, once it broke loose it spun fine. once in the water it was drained and refilled ran real smokey for a bit, needed new spark plugs too.
as for the starter, pull it off dunk it in a gallon of denatured alcohol. then take it for a check out. as for the alt they are cheap enough to replace
Old 03-05-2009
tommays's Avatar
In most any case you want to run the motor ASAP to prevent rusting of the cylinder walls
You have freshwater so it is much better than salwater if there is no freeze damage
The issues i see in the long term are that anything electric will have to be rebuilt as the trapped water will result in failure over the summer
I would check the dip stick to see if there was a lot of water inside, if so pump out the oil and change the filter
I don't know I it as high enough to enter the cylinders BUT in any case you DO NOT want to risk turning over the motor with the spark plugs in until this is know
Be very careful when turning over a motor with water in the cylinders as it will be forced out with a LOT of pressure that can cause personal injury
I have to leave now good luck
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 03-05-2009
Angry
Thanks all,
I'm sure water didn't get high enough to enter the cylinders. I do know it is in the oil though. I pumped all the water I could out of the boat but there is still a large amount of ice in there. I'll have to put a heater in there to melt it. I am in eastern Canada - still cold here. What about the transmission? I assume oil could have entered this oil too? Maybe I'll get a small outboard this year. I wonder if insurance would cover this damage?
Atomic Is No Bomb sailnaway Atomic 4 9 10-21-2011 12:43 PM
Previous keel damage sab30 Boat Review and Purchase Forum 11 01-04-2009 11:32 AM
Pearson 36-2 rub rail damage Paysay Gear & Maintenance 3 07-12-2007 07:56 PM
Structural Damage Dan Dickison Buying a Boat Articles 0 06-16-2002 08:00 PM
Atomic 4 Woes Mark Matthews Gear and Maintenance Articles 0 10-03-2001 08:00 PM
