03-06-2009
Most bilge pumps, which are usually centrifugal impeller designs, don't generate much pressure. I would look for an actual washdown pump, which are usually diaphragm pumps, rather than centrifugal ones. A 3 GPM pump will generate about 50 PSI IIRC.
