Old 03-08-2009
Barking Dog
KindOfBlue is on a distinguished road
I broke the wire on my Temperature Sensor
I have a Yanmar 4JHE and while working on some other project, I busted the wire off the top of my Temperature Sensor (not sending unit).
What does this wire do, do I need to fix it and where can I get the part?
Thanks,
Craig
Craig
Old 03-08-2009
jason3317 is on a distinguished road
Does your connection to sender terminate with a ring terminal secured with a screw to the sender? If so, can I assume you broke it at the ring terminal?
I think you can just splice in a new section of wire using butt connectors. I would use heat shrink connectors and/or a separate piece of shink over the repair.
Old 03-08-2009
hellosailor's Avatar
Craig, in my experience a "temperature sensor" and "sending unit" are the same thing, so I'm not sure what you are speaking about.
Temp senders normally are a lot like a squat spark plug in appearance. There's usually only one wire attached, which runs to the guage cluster and then to a 12v positive source. Inside the sender is a thermistor, a blob that changes resistance when the temperature changes, which in turns controls the voltage flowing through the guage, which makes the meter needle move from C to H.
If you break the wire off, just fix it. Solder it, crimp a new fitting on the end of it, put in a foot of new wire if needed. Not at all critical, anything close will still work equally well.
Old 03-08-2009
Barking Dog
I just looked it up again in the service manual and this is called the Water Temperature Switch. This is in addition to the Temp Sending Unit.
There is a threaded end on the switch that screws into the fresh water pump. On the exposed end there is a wire that connects to it. I busted this wire off, but the way that it was connected is not typical like a ring terminal. It's like the end of the wire was attached by pouring plastic on top of the switch and when it solidified, it was stuck. Maybe I am over thinking this is just a type of soldering that I haven't seen before.
Craig
Old 03-09-2009
Craig, the wire may have been soldered or crimped on, and the plastic 'cap' added to help secure it against vibration, insulate it, or something else. Unless it was some type of plastic jacketed crimp fitting.
What is left for the wire to be connected to? Any type of stub, post, bit of metal to re-attach it to? If there is, you can probably try to resolder it to whatever metal there is (which may mean scratching out a bit to get the contact area) and then apply some epoxy putty (i.e. plumber's epoxy or JBWeld, more heat resistant) as a new cap over it. How well that will work depends on what you've got left. And whether you can afford to risk it failing in future.
Old 03-09-2009
Gary M's Avatar
Gary M is on a distinguished road
Any Yanmar dealer should be able to supply the sensor and wire, probably your best bet. Not likely to be too expensive. Torresen Marine will supply online.
Gary
Sta-Lok or ? killarney_sailor Gear & Maintenance 22 11-06-2008 08:55 PM
Offshore Log: Check Your Lifelines, Save Your Life PracticalSailor Gear and Maintenance Articles 3 04-26-2007 12:23 PM
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
