Old Bronze Quadrant Removal - Help!!! - Page 2 - SailNet Community
post #11 of 13 Old 03-12-2009
STARBOARD!!
KeelHaulin's Avatar
OK looking at those pictures a second time makes much more sense now. The upper piece you are trying to remove may have an interference fit between the bearing and the shaft. I can't see clearly but another possibility is that the shaft is tack welded to the bearing (in the side view it looks like there may be a couple of tack welds hidden beneath rust).
Are you going to drop the rudder once the quadrant is off? If so; you could cut the rudder post between the quadrant and the rudder tube with a sawzall and then remove the quadrant with the upper part of the post still attached and take it to a machine shop for final disassembly.
KeelHaulin is offline
post #12 of 13 Old 04-15-2009 Thread Starter
kckclass's Avatar
Got it
I didn't read your post but you hit the nail on the head - except for the drop the rudder part - it had to go to the trash not to the bottom.
The sawz-all was replaced by a 7 inch cutting wheel - I lashed the upper rudder post and hauled it about a foot out of the rudder log, cut, rotate, cut, rotate (1 3/8 diameter) and then once cut, bang, bang, bang and PLOP - out she went - hauled her to the surface, dumper her in the dink and hauled her away.
I've drilled the new holes for mounting the quadrant in a new place and need to go to the shop to have it slipped out of the quad if I want to use the same shaft in a 90 degree position to drive the tiller arm on the new rudder already installed.
Otherwise, I am home free.
Craig Mead
Founder and Teacher
Kids Computer Kamp (KCK)
Free PCs for Kids since 1983
(Eduhosting.org/edkck.html)
and Woodcarver (trained by NASA Physicist)
The most beautiful Wind Generator Blades on Earth
(WindGenZen.com) Free Wind Gen blade carving classes
kckclass is offline
post #13 of 13 Old 04-15-2009
Cabin boy
How about posting some pictures of your hull. I'd like to see what a movable sea-farm looks like.
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version. - Robert Gainer
JimHawkins is offline
Barnacles on shaft wchevron Gear & Maintenance 22 03-02-2009 06:17 PM
Auto-pilot installation strategies on quadrant steering Pub911 Gear & Maintenance 22 02-17-2008 08:40 PM
