Building an FRP Holding Tank & System - Page 2 - SailNet Community
post #11 of 15 Old 03-11-2009
Glad to help... Post photos of the installation when you're done and let us know how it goes.
sailingdog is offline
post #12 of 15 Old 03-11-2009
Originally Posted by Deadeye View Post
Just an addition here - it sounds like you've got the answers you're looking for.
Sealand makes a carbon filter that you plumb into the vent to kill odors. From the ones I've seen (smelled...), they are probably 75% effective vs no filter. No idea what they cost though - for us it's just another service item.
Wouldn't recommend it, as it will restrict airflow drastically, leading to a stinky holding tank, leading to needing the filter... good ventilation is a better, and cheaper solution in the long run.
In powerboats up to about 45', the 10 gallon Sealand holding tank is pretty ubiquitous here - I don't think I've ever been asked to install a bigger one.
FWIW I plan to build my own as well from epoxy and ply and the inner coating of epoxy will probably be laced with graphite to make it harder and more 'slippery'. I'd caution against using epoxy with mat because mat requires styrene based resin to dissolve into a 'mush'. It will physically work to build up bulk, but it's pretty wasteful of epoxy IMHO.
I used to work for a shop that built sportfishers to about 30'. They used a solid 'glass tank made over a triangular plug mold that fit in the forepeak against the stem. I always wondered why they gelcoated the outside but not the inside of the tank...ewwww.....
Chopped Strand Mat is usually held together with a binder that dissolves in the styrene found in polyester/vinylester resins. However, there are now some "epoxy" friendly CSM mat materials available. I prefer to build thickness with cloth, because it is stronger than CSM is.
post #13 of 15 Old 03-11-2009
Bender of Nails
SD, you make a good point (as usual) about the use of vent filters. What I've seen in boats that come back in the fall that have seen use during the season though, is that the pumpout process draws air into the tank regularly enough that the filters seem to work pretty well. Most folks with newer boats seem to be pretty thorough about rinsing the tank after pumping out as well. Your post does remind me of a caveat I should have mentioned when suggesting the filter in the first place. The Sealand tanks we use have them already, but if I were fabricating a tank, I'd definitely add a tanksaver valve. If that filter ever jams up after overfilling the tank it probably won't clear itself...
I agree with you on building up with cloth. The whole point of epoxies are that they are stronger in laminate so you need less. In a conventional layup, mat is there primarily as a means to add density to the laminate, like filling the weave between structural cloth layers or reinforcing what will become outside corners within a female mold. To use the same technique with epoxy demonstrates an ignorance of the material's advantages.
JMHO of course.
Matt, you were asking about level indicators as well.
Again with the Sealand stuff (not a shill, it's just what I've used most), their Tankwatch system is pretty idiot-proof. It uses a series of coloured LEDs to give you an indication of the tank's level. Their are a couple things to watch when installing them, but they work pretty well once set up. If you leave a long enough pigtail of wire (or use disconnects), it can be used as an inspection port /cleanout as well.
The Heart TankTender system takes a bit on the part of the user and costs a fair bit more, but there's only a 1/8" air line going into the tank and the same guage can read multiple tanks containing different fluids. Oh, and it requires no electrical power to run...
Regarding your concerns about inspection plate fasteners penetrating the tanks: you could either add a plywood ring to the top of the tank, which is what it sounds like you were alluding to, or you could use anchor nuts (tee nuts) and glass right over the bottom of them.
"Verbosity leads to unclear inarticulate things"
~Dan Quayle
Deadeye is offline
post #14 of 15 Old 12-14-2009
Tank size calculation
Originally Posted by matt2 View Post
So for 2 people, 15 days between pump outs would make it
5*2*15=150 litres? -> divide by 3.8 to get 40 Gallons
So since 1000 cubic cm is 1 litre, to get 150K cubic cm the rough dimensions would be 100cm*15cm*10cm, which is workable.
What size tanks do other boats have?
Are there downsides to excessive tanks size?
Are folks happy or unhappy with your tank size?
100cm*15cm*10cm is only 15,000 cubic cm (15 litres). If you want 150 litres (150,000 cubic cm) you will need to increase the volume by ten times.
RobinAtkinson is offline
post #15 of 15 Old 12-14-2009
Cal 9.2 SilverSwan
roline's Avatar
My boat had a 10 gallon Vetus bladder tank that developed odor issues, I replaced it with a custom fabbed tank just behind the head to keep the hose length to a minimum. It is a 15 gallon epoxy and fiberglass tank. 12 layers thick with a slick coat on the inside and 45 degree fillets on all internal corners. It takes up 1/2 of the hanging locker, but the stowage that was consumed by the bladder is now usable. A HDPE tank would have been prefered, but I could not find on that fit the space and the cost of a new mold was too much $$$.
Cal 9.2 #19 SilverSwan
roline is offline
Siphoning holding tank Sixbrothers Gear & Maintenance 18 10-24-2008 11:08 PM
holding tank removal gwhar Gear & Maintenance 4 10-03-2008 08:39 AM
Holding tank or Type 1 MSD for Cal 39 costaricanwannabe Cal 4 03-13-2007 06:10 AM
Holding tank jeanneau 51 Myblueheaven Living Aboard 3 05-25-2006 04:06 PM
Sealand Holding Tank System sjacovino Gear & Maintenance 4 02-08-2001 02:48 PM
