03-10-2009
You really want to use a toggle, as it will help prevent the stainless steel wire from working and fatiguing in that location. The mechanical fittings, like the one in your post (Norseman, StaLock, Hayn HiMod) are a great idea, but fairly expensive. A good compromise is to go with swaged fittings at the top and mechanical fittings down at deck level, where corrosion is more of a problem with swaged fittings.
Swaging the wire directly to the tang is a really bad idea, since you won't have a clevis pin and cotter to remove if you need to disconnect the rigging.
