Hose removal with dremel? - Page 2 - SailNet Community
post #11 of 12 Old 03-12-2009
Originally Posted by r.furborough View Post
Plus some hoses are subject to a vacuum during pump-out, a reinforced hose will resist collapse.
I suspect the only way to create sufficient vacuum in that scenario would be from a clogged vent hose in which case multiple hoses as well as the holding tank would all collapse as well.
k1vsk is offline
post #12 of 12 Old 03-12-2009
Actually, the head would generally let enough air/water through to preven the tank from collapsing.
sailingdog is offline
Propane hoses & Barb fittings plus hose clamps surftom Gear & Maintenance 5 07-21-2008 11:56 AM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
