Old 03-12-2009
montenido's Avatar
montenido is on a distinguished road
Electrical Wire Crimping Tip
Hi all, I just finished installing my new battery charger (Xantrex Truecharge2, 40amp) today. While putting together the wiring, which was 6 and 8 gauge, I was trying to figure out how to make good crimps without buying another expensive tool. I had to make one more trip to WM (of course) to get more wire, ring terminals and heat shrink. As luck would have it, I brought 3 pre-cut wires with me to make sure I bought enough fittings. Anyway, on my way to the register I took a lap through the sailing tackle section, and what did I spy? A bench-mounted crimper. So I just pulled my fittings and heat shrink out of the packages and put them together using WM's crimper. Very nice indeed! I figured, what is the worst they could do to me? Tell me to stop? Nobody even noticed and I built 4 complete lines. BTW, if they gave me sh*t for using their stuff I was going to remind them of how much I have spent in their store.
Thought you all might like to know. Especially if you just need to do one or two wires. And yes, I did pay for the fittings, etc.
Good luck, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 03-12-2009
huguley3's Avatar
huguley3 is on a distinguished road
I don't think they mind at all. The dockmaster here mentioned that they had one and I asked if I could use it and they said sure no problem and the bolt cutters are under the bench if you need to size the cables. While I was there crimping cables I pointed a customer to where the nuts and bolts were.
30' Islander Bahama
Old 03-12-2009
Hunter07 is on a distinguished road
I like West Marine
After a re-cut of my jib I needed a short cable (pendant) about a foot long to go between the swivel and the sail. The West Marine person said they do not make these to order (liability reasons) but walked me thru the whole process. She helped me pick the right wire cable, the correct crimps, and the correct thimbles that go in the loops. Also gave me directions on how to do the crimping right. I had a friend with me so he held everything and I did the crimping. The WM lady said to just bring the empty bags for the parts to the register and tell how much and what size cable to ring me up. I would be surprised if they not only didn't say anything about crimping wire connectors but would probably suggest it or the West Marine I go to is just full of nice people.
Old 03-12-2009
montenido's Avatar
Damn! I thought I pulled one over on them! Well it is good to know that they allow it. I'll be back with some other stuff to crimp.
Bill
Channel Islands, CA
Mark Twain
Old 03-13-2009
The bench mounted crimper, was it a hammer driven one? If so, they don't make a really good crimp most of the time. The ones that look like bolt cutters do a much better and more consistent job of it.
Old 03-13-2009
Dutch1951's Avatar
Dutch1951 is on a distinguished road
I broke down and bought a crimping tool years ago. Money well spent. It's one of those specialty tools that you don't use much, but is worth it's weight in gold when you need it. Quality tools, especially avionics tools are something best not to scrimp on.
Old 03-13-2009
k1vsk will become famous soon enough
Not sure if this applies nationwide but at the three WM stores local to me in RI, all have the proper crimping tool as well as swagging tools and allow anyone to use them, with or without supervision. Certainly makes sense to pay the small price to purchase the materials there with this as the benefit.
Given the criticism WM often receives here and elsewhere, particularly in their pricing, they deserve some credit for this unique customer service.
Old 03-13-2009
JohnRPollard's Avatar
Moderator
Ditto. They've got the same bench tools down here in Chesapeake country. In my experience, they are always happy to let folks use them, especially if you're buying some of the fittings, cable, or wire from them.
I ask permission first, just as I would prefer someone to do if they borrowed my tools. But they probably don't care one way or the other. Also, I find when I ask, some of their employees are eager to help out and often have good advice.
Old 03-13-2009
Maine Sail's Avatar
not
The crimp tools mounted to the work bench at most WM stores are sized for nico press swage sleeves not electrical crimp connectors... As such it will be guess work at best to ascertain whether you have actually made a true cold formed crimp. If using these tools I would advise cutting a fitting open right in the middle of the crimp then hitting it with a drill mounted wire brush to see if any wire ends expose. If you see individual strands instead of one solid mass of copper the crimp is not a good one..
It may very well make a solid crimp but to be sure I'd certainly want to visually inspect one especially on that gauge wire..
______
-Maine Sail / CS-36T
Old 03-13-2009
The crimp tools mounted to the work bench at most WM stores are sized for nico press crimps not ectrical... As such it will be guess work at best to ascertain whether you have actually made a true cold formed crimp..
Actually, they have both at the stores I mentioned
Offshore Log: Check Your Lifelines, Save Your Life PracticalSailor Gear and Maintenance Articles 3 04-26-2007 12:23 PM
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
