  #11 (permalink)
Old 03-13-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
On a tangent...I read that motorsailing can have stresses on the engine/trans/shaft mounting that aren't expected in the same way as just motoring.
When the boat is at rest, run lines across the interior of the cabin at a few spots in the general area of the engine. Then go sailing. When heeled over, are the lines still fairly tight? If not, the hull is flexing. What is happening to the motor mount, transmission & prop shaft during this hull flexing??? The more the flex the more you should be concerned with getting out of alignment during motorsailing, if heeling.
  #12 (permalink)
Old 03-13-2009
sideyb's Avatar
sideyb is on a distinguished road
Thats interesting, never had an issue with that.
  #13 (permalink)
Old 03-13-2009
hellosailor's Avatar
"How about Bull Dozer's"
Bulldozers are actually damned expensive equipment, with way more routine maintenance than you might think. You don't just use them and change the oil every six months.(G)
I'd bet the folks at Caterpillar would tell you they don't just drop in truck engines, either.
  #14 (permalink)
Old 03-15-2009
Shortman is on a distinguished road
15 degrees
per Larry Berlin @ Mack Boring. Mine is a 3GMF. The oil sump on a bulldozer is probably like that of our Kenworth truck which holds several gallons, not a few quarts like a little marine diesel.
  #15 (permalink)
Old 03-15-2009
jrd22's Avatar
Courtney the Dancer
Something other than damage to the engine to consider if you are motorsailing while heeling over is getting air in the fuel system. If you have port and stb. fuel tanks and a crossover line between them (with the valve open) the fuel will flow to the downside and if your engine pick up is in the high side tank you can suck air in (voice of experience talking).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Trying to get an older Universal diesel running...experience appreciated! countrybumpkin Gear & Maintenance 22 09-13-2008 03:50 PM
Running Diesel To Charge Batts = Bad stoutwench Gear & Maintenance 30 04-03-2007 09:06 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Running Backstays Dan Dickison Gear and Maintenance Articles 0 05-14-2002 08:00 PM
