Old 03-13-2009
tausap is on a distinguished road
I just did both Lewmar 48s on my boat the other day. It was my first time and I did not find it difficult. Take the winch drum off one of the other winches but leave it put together as it makes a good reference to how all the gears go back together.
I used grease on everything, including the pawls, when I did mine. It was only later that I read somewhere that the pawls should be oiled, not greased. I'm going to leave it as is for now and see how it does. If they are sticking I am going to have to re-do it.
Have lots of rags/paper towels handy as it is a messy job!
Brett
S/V Liberty
1980 Morgan 461
  #12
Old 03-13-2009
c40eb's Avatar
Vikingsailor
c40eb is on a distinguished road
I have access to the through bolts holding my winches down, so I think I could have removed them...but...weather wasn't bad for Maine, this time of year...so...I did the job on board. Didn't lose anything...but did stab my finger with one of the springs...minor!
The single speed winches were very easy. The 2 speeds took longer...much more to clean. No surprise.
Originally Posted by Sapperwhite View Post
now that i think about it, in order to get the entire winch off the boat you'd have to strip it down.
It's not whether you're paranoid...it's whether you're paranoid enough.
s/v Cloudman
1988 Sabre 30
  #13
Old 03-13-2009
ASA and PSIA Instructor
Originally Posted by tausap View Post
I just did both Lewmar 48s on my boat ...I used grease on everything, including the pawls,.... I'm going to leave it as is for now and see how it does. If they are sticking I am going to have to re-do it.
A way bad idea, as you run the risk of finding out they are sticking when a loaded winch unloads while the handle is in, you can take someone's teeth out or crack a skull. Note you will only notice the pawls are sticking AFTER the last one sticks...only one needs to be working for the operation to look normal. When the last pawl sticks open - BAM!
Take the winches apart clean and properly oil the pawls. Be sure that the teeth and races that the pawls set in have not been greased either.
  #14
Old 03-13-2009
billyruffn's Avatar
billyruffn will become famous soon enough
Originally Posted by SollaSollew View Post
Thanks much. Looks like a half an hour per winch once you get established.
I'm wondering how a proper winch stripping & maintenance can be done in 30 minutes:
1. remove the winch from it's base (usually necessary to get all the parts disassembled) (est. 5 min)
2. disassemble the winch (down to singular parts) (est. 10-15 min).
3. soak all parts in solvent (gasoline, kerosene, diesel, or other solvent) (est. 10 min)
4. clean all grease and solvent off parts with tooth brush and clean rags (est 20 min).
5. reassemble and lubricate parts as reassembly proceeds (oil on pawls, light coat of grease on everything else, plus tefgel on dis-similar metals) (est 20 min.)
6. remount reassembled winch on its base (est 5 min).
....and those times are after you've been doing it for a while.
I've done it on and off the boat, but my favorite way to do it is sitting at my garden table, under the unbrella, with cold beer at hand. That way, it doesn't matter how long it takes!
Tip: Buy extra allen wrenches of the required sizes and other necessary tools and keep them, along with all the grease, oil and spares, in a separate box marked "Winch Stuff". That way when its time to mess around with your wench you just grab the box and have at it.
  #15
Old 03-13-2009
can't name here 31
cssdengr is on a distinguished road
And I opened this post thinking the title was "How to service wenches..."
  #16
Old 03-13-2009
CaptainForce's Avatar
I noticed that the link in the second post suggested using "Lewmar grease" - whatever that is... I've always used and been pleased with the white lithium grease for this application.
  #17
Old 03-14-2009
c40eb's Avatar
Vikingsailor
Oh my...
s/v Cloudman
1988 Sabre 30
  #18
Old 03-14-2009
c40eb's Avatar
Vikingsailor
"Lewmar grease" is just a tube of grease w/the Lewmar name on it. Comes in the winch kit you can get from Lewmar. It's their special, proprietary blend. HA!
s/v Cloudman
1988 Sabre 30
  #19
Old 03-14-2009
funjohnson's Avatar
A New Adventurer
funjohnson is on a distinguished road
Mine are not that old either. Do I need to get the winch service kit or could I just use the lithium grease? What about the oil? What type would you recommend?
  #20
Old 03-14-2009
Tausap—
I'd have to second what SF said, you really need to take the winch apart and clean off the pawls. That's really not a good idea to leave them as is.. A Lewmar48 is a decent size winch and the loads on it are going to be high enough to be dangerous. By the time they start sticking you may not realize it and you're risking getting mauled by it, like the old wire reel winches used to do to people...
Just be aware that there are commonly two spare parts kits for Lewmar winches. One is for their single-speed winches, the other for their two-speed winches.
You may post attachments
You may edit your posts
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Sailing with E-Mail Kathy Barron Gear and Maintenance Articles 0 09-04-2000 08:00 PM
Sailing with E-Mail Kathy Barron Her Sailnet Articles 0 09-04-2000 08:00 PM
SEO by vBSEO 3.6.1
