How to service winches - Page 3 - SailNet Community
post #21 of 31 Old 03-14-2009
About greases. I have been told that not all greases are compatible. So pick a grease, clean everything else off with solvent, and stick to that grease.
gc1111 is offline
post #22 of 31 Old 03-14-2009
The Lewmar kit says it is for “winches less that 10 years old”…our winches are 20 years old...is there a kit for us?
PearsonCommander is offline
post #23 of 31 Old 03-14-2009
Bristol 45.5 - AiniA
Stick with winch grease
Originally Posted by funjohnson View Post
Mine are not that old either. Do I need to get the winch service kit or could I just use the lithium grease? What about the oil? What type would you recommend?
I would use the correct grease. You use so little of it that the cost is minimal. I have heard that lithium grease can cause an electrolytic reaction since lithium is a metal - no idea where it is on the nobility scale.
killarney_sailor is offline
post #24 of 31 Old 03-15-2009
Not So Senior Member
Sapperwhite's Avatar
Galvanic series in seawater....
* Graphite
* Palladium
* Platinum
* Gold
* Silver
* Titanium
* Stainless steel (316 passive)
* Stainless Steel (304 passive)
* Silicon bronze
* Stainless Steel (316 active)
* Monel 400
* Phosphor bronze
* Admiralty brass
* Cupronickel
* Molybdenum
* Red brass
* Brass plating
* Yellow brass
* Naval brass 464
* Uranium 8% Mo
* Niobium 1% Zr
* Tungsten
* Stainless Steel (304 active)
* Tantalum
* Chromium plating
* Nickel (passive)
* Copper
* Nickel (active)
* Cast iron
* Steel
* Lead
* Tin
* Indium
* Aluminum
* Uranium (pure)
* Cadmium
* Beryllium
* Zinc plating (see galvanization)
* Magnesium
Dictated, but not read.
Sapperwhite is offline
post #25 of 31 Old 03-16-2009
I'd imagine that Lithium is very low on that scale, since, in its natural form it reacts with water briskly, not quite as bad as Sodium. Same family as Sodium IIRC...
sailingdog is offline
post #26 of 31 Old 04-04-2009
S/V Pearl Bristol 45.5
If you're going through the process not a bad idea to replace the parts - we had a pawl that looked brand new but was worn just enough - that allowed drum to reverse. Replaced it and all is good. WD40 is a good cleaning agent and be very sparing with the new grease.
SV Pearl is offline
post #27 of 31 Old 04-04-2009
STARBOARD!!
KeelHaulin's Avatar
Here are two kits that I bought for my 42's and 55-ST's:
Lewmar P/N - 19700200 - Winch spares kit for 2-speed winches (size 6 to 64 winches)
Lewmar P/N - 19700100 - Winch spares kit (basic) - for smaller single speed winches
I'd say that many of the parts in these kits will fit older winches; specifically the pawls, pawl springs, spring clips and shaft retainers. Several parts in these kits are for newer winches and will be throw-away depending on your winch model/age. Be VERY careful with any of the other internal components in your winch like caged bearings; gears, stripper rings, plastic sliders, etc. If it goes in the drink you'd be better off to hire a diver than try and find a replacement; many of these parts may no-longer be available from Lewmar.
WD-40 tends to gum up when it gets wet with salt-water; as does many types of grease. I only use the Lewmar products; even if used liberally it is not very expensive and will last quite a long time between rebuilds.
P/N 19701100 - Calcium Sulphonate Grease (tub)
P/N 19701600 - Pawl Oil (55ml) - Put this in a sealed ziplock and store upright because it tends to leak once opened
KeelHaulin is offline
post #28 of 31 Old 04-04-2009
Aeolus II
mccary's Avatar
Originally Posted by k1vsk View Post
everything you ever wanted to know:
http://www.c36ia.com/files/Lewmar%20...0SJ%207-06.pdf
Thanks, I will save that PDF for reference later.
Joe McCary,
Sailing on The Central Chesapeake Bay, West River, MD on my Catalina 27, Aelous II with my wife and friends.
Sailing Blog:
mccary is offline
post #29 of 31 Old 04-05-2009
Pawls and springs for older Barient #22 and #10 winches
I have Barient #22 and #10 winches, era unknown but presumably older, and likely > 10 years. There is a pawl/spring kit available for Barient winches, but one website said it was only for winches < 10 years old. Does anyone know more about this? Thanks.
floatsome is offline
post #30 of 31 Old 04-06-2009
Quick reply.. Advice an old guy told me --
He said when servicing a winch, take a cardboard box (like a shoebox) and cut a hole in it with a pocketknife, slightly bigger than your winch, then tape the box to your deck leaving the winch sticking through the hole.. you can't lose a part if you try
1984 Starwind 22
"Julianne"
WheresTheBrakes is offline
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 09:00 PM
Sailing with E-Mail Kathy Barron Gear and Maintenance Articles 0 09-04-2000 09:00 PM
Sailing with E-Mail Kathy Barron Her Sailnet Articles 0 09-04-2000 09:00 PM
