Old 03-13-2009
SollaSollew is on a distinguished road
How to service winches
I am looking for advice on winch servicing. I have Lewmar winches, I don't know the sizes off-hand but there are two primary and two secondary on the coach roof of my Bavaria 33. Is it just a questions of taking them apart, cleaning them and re-assembling them or are there standard parts that need to be replaced regularly. I was not aware that this needed to be done annually so they haven't been touched since the boat was new in 2007.
Also, does the project have to be done on the boat or can they be taken off and done at home. About how long does it take for someone who is generally pretty good with tools? Any things to be particularly careful about other than parts going into the water.
Thanks.
Eric
Old 03-13-2009
k1vsk will become famous soon enough
everything you ever wanted to know:
http://www.c36ia.com/files/Lewmar%20...0SJ%207-06.pdf
Old 03-13-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
In addition note how the pictures show towels draped over the lifelines so hopefully parts don't fall overboard. Some people have suggested cutting a hole in the bottom of a cardboard box and placing it over the winch before tearing it down; but that might restrict getting at the gear pins too much.
Be careful when pulling the drum off because the caged needle bearings like to stick inside the drum and then fall out unexpectedly.
Old 03-13-2009
gc1111 is on a distinguished road
The thing that seems to cause the most trouble is the small spring (really just a bent piece of spring wire) that controls the pawls.. It loves to jump long distances when you remove the pawls and if you are not expecting it............
Old 03-13-2009
A great resource. It appears as if the author of the PDF did NOT replace any part but rather simply cleaned and lubricated everything. Is this correct?
Eric
Old 03-13-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
This from a google search on 'Lewmar winches'
Lewmar
On new winches you would not expect to be needing to replace ANY of the parts. Just clean and re-lube as per instructions. Pretty straight forward.
Good luck.
Old 03-13-2009
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
if you have Lewmar winches, they sell a relatively inexpensive kits. you will want a "Lewmar Winch Maintenance Kit"
the kit includes an instruction manual , winch grease, oil, a brush for the grease, and 10 pawl springs. The trick is that two speed winches use 4 pawl springs each, so you may have reuse some springs doing 4 winches. That shouldn't be a big deal on an 2007 boat.
The kit is under $30 and be found at about any store, WM, Defender, Sailnet Store:
Lewmar - Winch Maintenance Kit Shop.Sailnet.com - sailing resources, shopping, sail, blogs
url is crappy.... just click on the lewmar name
Dictated, but not read.
Old 03-13-2009
c40eb's Avatar
Vikingsailor
c40eb is on a distinguished road
I just finished the winch maintenance on my boat. Boat is on the hard. Didn't remove the winches from the boat...and all went well.
Didn't replace any parts, as I did not see any signs of significant wear. Pawls, bearings, springs, all looked fine. I do have a good supply of spares for the eventuality.
Cleaned all the old, gummed up grease, oiled the pawls, greased everything else and reinstalled.
Not a bad job...
It's not whether you're paranoid...it's whether you're paranoid enough.
s/v Cloudman
1988 Sabre 30
Old 03-13-2009
Originally Posted by c40eb View Post
I just finished the winch maintenance on my boat. Boat is on the hard. Didn't remove the winches from the boat...and all went well......
Not a bad job...
now that i think about it, in order to get the entire winch off the boat you'd have to strip it down.
Old 03-13-2009
Thanks much. Looks like a half an hour per winch once you get established. Will wait till weather is warm enough to work on the boat our of doors. Officially I can go sailing on Sunday when my insurance is valid. I will undoubtedly wait at least a few weeks though.
Eric
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Sailing with E-Mail Kathy Barron Gear and Maintenance Articles 0 09-04-2000 08:00 PM
Sailing with E-Mail Kathy Barron Her Sailnet Articles 0 09-04-2000 08:00 PM
