Is there a way to rebed deck hardware without an assistant? - Page 2 - SailNet Community
post #11 of 24 Old 03-15-2009
Courtney the Dancer
jrd22's Avatar
I second the impact driver approach, they work great, and usually won't spin the bolt if the nut is snugged up by hand. I carry one on the boat all the time. I hate using vice grips on threads, although it's necessary at times, and it's impossible to get two hands into a lot of the areas where deck hardware comes through.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #12 of 24 Old 03-15-2009
JRD—
I don't recommend using vise grips on threads...but on nuts...
sailingdog is offline
post #13 of 24 Old 06-20-2009
jarcher's Avatar
Hex head bolts and an impact wrench!!
MS, I have seen you post about impact wrenches several times and I look at the picture, and I am always confused. What exactly does this tool do? The angle that the socket makes to the drive shaft seems to say that it does not turn that socket.
jarcher is offline
post #14 of 24 Old 06-20-2009
The wobble metween extension and socket allows you to make some decent angles.
An alternate that I prefer in many cases is a flex extension, more or less springs and wire that allows very smooth curves, and with care can do 180 degrees, 90 with ease.
Ken.
merc2dogs is offline
post #15 of 24 Old 06-22-2009
timebandit's Avatar
Make a friend.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #16 of 24 Old 06-22-2009
Hunter 33.1
NolaSafari's Avatar
This was my fathers day gift, my loving wife came out to the boat to assist me in installing stanchions and bow pulpit. BTW I gave her an electric smoker for mothers day.
S/V Haven't named yet.
NolaSafari is offline
post #17 of 24 Old 06-23-2009
Tundra Down
downeast450's Avatar
Super Glue? I use super glue to "build" a collection of washers and the nut for difficult to reach places. I know this doesn't address the specific issue here but it could make part of it simpler. I put a little clay in the socket, press the washers and nut (all one piece thanks to super glue) into the socket and reach the collection up to the threaded end of the fastener with an extension and it stays together long enough to take a few truns with the socket. I haven't tried super glue to hold the fastener from above but it might do a good job.
downeast450 is offline
post #18 of 24 Old 06-24-2009
jarcher's Avatar
Is a 1/4 inch drive impact wrench sufficient for most boat jobs, or is a 1/2 inch needed?
jarcher is offline
post #19 of 24 Old 06-24-2009
Depends on the boat...but I'd go with at least a 3/8" not a 1/4" drive impact wrench.
post #20 of 24 Old 06-24-2009
Maine Sail's Avatar
My 1/4"
Even my inexpensive 1/4" Ryobi will snap a 5/16" bolt clean off with ZERO effort. Be very, very careful going with a high torque impact driver you don't need 200+ ft pounds!!!
I prefer the 1/4" as there are more places I can get it into than most 1/2" drivers. Getting deck hardware tight on a 30 to 40 footer should be no problem for even the smallest 1/4" impact driver. Hell you could squish the deck core easily if you can snap 5/16" bolts..
______
-Maine Sail / CS-36T
Maine Sail is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
