Is there a way to rebed deck hardware without an assistant? - Page 3 - SailNet Community
post #21 of 24 Old 06-24-2009
jarcher's Avatar
Getting deck hardware tight on a 30 to 40 footer should be no problem for even the smallest 1/4" impact driver. Hell you could squish the deck core easily if you can snap 5/16" bolts..
Oh you use this to tighten the bolts??? I was thinking you just used this to remove them! How do you manage to tighten them without holding the bolt head in place?
I usually hand tighten so I don't risk over tightening...
jarcher is offline
post #22 of 24 Old 06-24-2009
Maine Sail's Avatar
The magic of an impact driver is the compression blows that allows you to tighten from one side but you need to be careful. Very infrequently will the bolt head spin, enough to be a problem, when using an impact driver.
If I am bedding with butyl and don't want any spin at all I flatten and then tape a wrench to the deck with Gorilla Tape and then use the impact driver and it works like a charm.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #23 of 24 Old 06-25-2009
To clarify, when I said the 3/8"impact driver made more sense, it was in the context of removing, not installing hardware.
sailingdog is offline
post #24 of 24 Old 06-25-2009
Cal 9.2 SilverSwan
roline's Avatar
I've used vice grips on the nuts for stanchions, toerails etc, doing the rebeading by myself. In most cases, phillips headed screws on the top side.
Cal 9.2 #19 SilverSwan
roline is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
