Old 03-14-2009
sailhog has a spectacular aura about sailhog has a spectacular aura about
fresh water pump problemo...
I let the fresh water tank get depleted a few days ago, and after refilling it, the pump runs continuously without fully pressurizing the system. I've got a faint stream running out of the tap instead of a nice hearty flow I had before. Can air in the system cause these symptoms? Do I need to somehow prime the pump, as it were?
Old 03-14-2009
gc1111 is on a distinguished road
Probably needs priming, but without a description of the system it is hard to tell. My pump will self prime only with no backpressure - so I open every tap on the boat and wait until it primes - I can tell by the sound of the pump.
Old 03-14-2009
jackytdunaway's Avatar
'87 Pearson 27'
jackytdunaway is on a distinguished road
I had that happen once and i undid the pipe right past the pump so it didn't have to fight any pressure anywhere and it kicked in right away
Old 03-14-2009
lharmon is on a distinguished road
jackytdunaway is right. Simply remove your output line and replace it with the pump running and you should have pressure.
It's better to have your enemies inside your tent pissing out than outside your tent pissing in...
Old 03-14-2009
GC, Jacky, lharmon: thanks to you all. GC's suggestion was simplest, so I tried it and it worked. Tell me if I'm wrong, but I think you all gave me something of the same solution. In any event it worked. Once again,thanks to you all!
Old 03-14-2009
'87 Pearson 27'
They are all the same. Taking the pipe loose is more trouble but takes away the issue of the hot water heater leaving some pressure. Always try just faucets 1st
Water filter with manual pump faucet? IslanderGuy Gear & Maintenance 7 12-24-2009 08:06 AM
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 10:33 PM
Sailboats Fresh Water System? 1970Columbia34 Gear & Maintenance 3 02-19-2007 11:37 AM
Beyond the Bucket Brigade Brian Hancock Seamanship Articles 0 01-01-2003 07:00 PM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 04:17 PM
