03-16-2009
The AutoComp 1000 employs KVH's breakthrough digital fluxgate compass technology to provide precision heading data to an array of systems, including autopilots, GPS, video charts, radars, computers, and other electronic instruments. Designed as a remote sensor, the AutoComp 1000 can be mounted in a magnetically "clean" location (e.g., away from speakers, motors, wiring bundles, and other sources of changing magnetic fields), and its continuous automatic compensation feature ensures that the most precise heading data (within ±0.5°) is available at all times. The AutoComp 1000 is fully compatible with the NMEA 0183 output standard and a universal interface card is available for use with other interface standards. AutoComp 1000S is a ±45° gimballed, free-floating coil version for sailboats and AutoComp 1000P is a ±25° strap-down, free-floating coil version for power boats.
Highlights:
* Remote sensor with continuous autocompensation ensures reliable heading data at all times
* Accurate to within ±0.5°
* Fast 10 Hz NMEA 0183 standard output compatible with other ARPA radars, autopilots, and other electronic systems; optional interface card available for other outputs
* Options include mounting bracket and extension cables
* Variants for use aboard sailboats and power vessels as well as in OEM applications
I have one and getting any info out of them is a bit hard as there phone is allways busy becasue there TracVision systems are the big sellers now
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
