Old 03-16-2009
SSBN506's Avatar
SSBN506 is on a distinguished road
Sealing the hull and deck joint
I am going to reseal the hull and deck joint this year on my 25 ft 1978 challenger sailboat. I have yet to take off the rub rail to see what condition it is in. But I am getting water leakage from the joint in various spots. Because of the boats internal lining I can seal it from the inside.
My question is what is the best way to do this? I was thinking of using a 4 inch wide fiberglass strip and classing the two joints together. But I am wondering if the flexing of the hull might crack the patch. Would I be better off using a flexible compound?
Old 03-16-2009
The best way to reseal a hull-deck join is to disassemble it and then re-bed it... glassing it over after doing that is a good idea, but you want to seal the joint itself before doing so. If you don't water can get into the joint and freeze, causing big, big problems later on.
Old 03-16-2009
SSBN506's Avatar
Thanks for the advice Sailingdog. It will be interesting to see what i find when i remove the rub rail.
Old 03-16-2009
scottyt is on a distinguished road
you can also mix up some collodal ( sp ) silica and epoxy and use a spreader to pack the joint from the out side. this will stop water from getting in to the joint and then use fiberglass to add the strength on the inside
Deterniming what to do about my hull to deck joint on my project boat... Perithead Gear & Maintenance 13 10-14-2008 01:32 AM
Fiberglassing Over Hull Deck joint? snider General Discussion (sailing related) 3 06-23-2008 09:28 PM
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 06:43 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
Problematic Hull Deck Joint Dan Dickison Buying a Boat Articles 0 09-17-2001 08:00 PM
