03-17-2009
Hinterhoeller HR28
Oughtta work. Be careful of propane aboard. Store all heavier-than-air gasses (such as LP) outside,else any leakage will fill the bilge, and you can easily "blow the hatches".
Since we have a 2-burner Origo non-pressurized stove, we use a Heat pal (same type of canister arrangement as the stove), similar BTU's to your proposed unit, and it works fine. Ventilation is important, of course.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
