  #31 (permalink)
Old 11-21-2011
dvuyxx's Avatar
Super Member
dvuyxx is on a distinguished road
Was the lettering painted/sprayed on with Awlgrip as well? If it was a "lesser" paint, maybe it can be buffed out and then a rubdown with light buff with awlcare? First, if it is a paint that isn't as tough as awlgrip, it might be pulled off by rubbing hard with MEK.
David
Severna Park, MD
Pearson 35 - s/v Tiger Lily
  #32 (permalink)
Old 11-21-2011
neverknow's Avatar
neverknow is on a distinguished road
I'd be careful with MEK. It can get under most finishes. Not sure about Awlgrip? Even if it doesn't look like it right away later it might peel?
  #33 (permalink)
Old 11-21-2011
dvuyxx's Avatar
Super Member
neverknow, point taken ... I would keep the MEK right on the lettering and do small areas at a time. You can also backwipe with a wet rag to dillute the MEK after rubbing. With awlgrip underneath, your options are limited for removing an overlay of paint.
Found this from Awlgrip.
AWLGRIP ONLY: Solvents such as AWL-PREP -T0008, AWL-PREP PLUS-T0115, AWL-PREP 400-T0170, toluene, lacquer thinner, M.E.K., acetone, or kerosene may be used to soften or remove heavy build ups of grease and grime, felt tip markings, or aerosol spray paint on the AWLGRIP Topcoat
But to your point, proceed slowly testing in a small area first.
David
Severna Park, MD
  #34 (permalink)
Old 11-21-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
If it's not paint there's a product called marine formula by debond corp; I use it on all adhesive, including 5200.
It will not harm gelcoats
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Making Passage w/o a Rudder wind_magic Seamanship 60 07-16-2010 01:23 PM
help with lifes dream kimby Boat Review and Purchase Forum 37 12-02-2009 11:32 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
