lazyjack system - SailNet Community
Blogs
Old 03-17-2009
debnoznal is on a distinguished road
lazyjack system
Hi, I,m new to sailnet so please bear with me if this question about the lazyjack systems and sail slugs has all ready been answered. I sail a small 18' American Sail Boat in confined waters, single. My problem is when I come in I have to lower my main and come in up power (4hp kicker) I usually end up with a pile of sail in the cockpit, sometimes the wind catches it and it end up in the water before I can bunge it up on the boom, it's just a pain in the neck, hence the lazyjack system. Question? How far apart should the sail slugs be on a small sail like I have. I've heard one every 1', every 2' , 18". is there any rule of thumb...Thanks ..debnoznal
Old 03-17-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Place four equally apart per side, and that should do it....i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 03-17-2009
This is a 18' boat with a boom that's probably less than 9' long. Four would probably work, but is probably also overkill. That said, a good lazyjack system and mainsail furling system is described here.
Old 03-17-2009
SD,
That's the 4 I am typing about. I imagine 2 would work, but I think 4 would give more sail stacked. Less falling out?
Old 03-17-2009
Two might do it, three would work well on that small a boat, but the installation of four is not much more work and will be better. My boat had only a three leg system originally, and the four-leg system works much, much better.
Old 03-17-2009
Wink lazyjack system
Thanks to all for the info. I think I'll try 4 per side equally spaced, I can always add more if needed.
Steering System Spring Checkup Tom Wood Gear and Maintenance Articles 0 04-26-2004 09:00 PM
Steering System Spring Checkup Tom Wood Cruising Articles 0 04-26-2004 09:00 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 09:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 08:00 PM
Checking the Wheel Steering System Will Keene Gear and Maintenance Articles 0 07-31-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
