Polysulfide sealant and outside temperature? - Page 2 - SailNet Community
post #11 of 19 Old 03-20-2009
Maine Sail's Avatar
I just realized your in MD. You should be more than fine so I'd do it now. I thought you were talking about stanchions..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 19 Old 03-20-2009 Thread Starter
Unpaid Intern
josrulz's Avatar
Sorry Main Sail, while I'm in MD, the boat is in Connecticut. That's why I'm up there every two weeks, and it's a choice of this weekend or two weeks from now.
Does that change your opinion?
1984 Sabre 34 Mk I
josrulz is offline
post #13 of 19 Old 04-20-2009 Thread Starter
Unpaid Intern
josrulz's Avatar
Thanks!
I'm reviving my own thread, so this is OK, right?
Just wanted to send an update, since I rebedded my first chainplate this past weekend. While it wasn't cold out, it did help to search and read old posts and ask questions here on Sailnet, so thanks!
I used 3M 101 and had no problems. It appeared the core was sealed with epoxy, which is not factory, so it will be interesting to see if the other chainplates were also done.
The time-consuming part was getting the cover off the deck, and also cleaning it and the slot area. It had a lot of sealant in there. But the rebedding was a snap once everything was clean.
Anyway, here's a pic, before fully cleaning the chainplate up (so there's a little sealant residue still on there, but you get the idea). I hope it holds up!
-J
1984 Sabre 34 Mk I
josrulz is offline
post #14 of 19 Old 04-20-2009
Irrationally Exuberant
Nice, J. And very nice that a PO sealed your core there. Bodes well for other hardware--and tells you something about the quality of care.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #15 of 19 Old 04-20-2009
Looking good Joz.
-J
sailingdog is offline
post #16 of 19 Old 04-20-2009 Thread Starter
Unpaid Intern
josrulz's Avatar
Thanks sailingdog and arf145. Yeah, it's a good sign that it was sealed. It wasn't done the way I'd do it, but you can't have everything. I'll be interested to see if they've all been done this way.
1984 Sabre 34 Mk I
josrulz is offline
post #17 of 19 Old 04-20-2009
jarcher's Avatar
Two weeks before launch should be find from a curing standpoint. Just make sure you leave yourself enough time so that if something goes wrong, you'll have time to fix it.
It seems that every time I touch anything on my boat, something goes wrong
jarcher is offline
post #18 of 19 Old 04-21-2009
midlife crisis member
AllThumbs's Avatar
I re-bed all my stuff with 3M 101 when it was getting cold at night and all was well too. I think the 40 degrees for application is mostly so it's not too thick (viscous) to get it out of the tube.
Eric
I sail.
AllThumbs is offline
post #19 of 19 Old 04-21-2009
celenoglu's Avatar
You can leave two light bulbs inside the boat near the chain plates. The heat will be enough to keep the area warm. In this way you will not need a tent.
celenoglu is online now
