Old 03-19-2009
mcrags is on a distinguished road
Vivid bottom Paint
I have Vivid Yellow Bottom Paint on a Catalina 42, looks great but is not smooth (used to use VC-17) Has anyone burnished Vivid? The Vivid rep. said that it would be a waste of time to burnish, any thoughts? McRags
Old 03-20-2009
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
My opinion is; if you want to drastically reduce the lifespan of your already-short-lived Vivid bottom, go ahead and burnish. That stuff is so soft, a harsh look will take most of it off.
"Clean bottoms are FastBottoms"
Old 03-20-2009
tager's Avatar
tager is on a distinguished road
What is the point of Vivid? Just better colors?
It's the bottom of the boat for chrissake!
Old 03-20-2009
Fstbttms's Avatar
Old 03-20-2009
lancelot9898 is on a distinguished road
Prop Coat
Speaking of Vivid bottom paint by Petit. If anyone has the latest issue of the Jamestown Distributors Catalog take a look at the back few pages which gives a summary of Petit Paint. There's a table showing what systems are best for coating underwater metal including props. The Zinc Barnacle Coat is shown as a good system, but the Vivid Paint is shown as a better and a best system after appropriate prep. It seems to me that their Trinidad SR is the best bottom paint that they make, but yet they reccommend the Vivid. Reasons??
Old 03-20-2009
Interesting that the rep said that since the catalog says that it's "easily burnished to a high performance racing finish."
Old 03-20-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
I think that is assuming you have put enough coats on to maintain a good film thickness once you have wet-sanded it smooth. Usually this sort of prep is done in the yard at great time or expense. I have seen photos where it looked as smooth/shiny as the gelcoat above the waterline.
Vivid is closer to an ablative than a hard anti-fouling; and I think you are not supposed to scrub it heavily or very often.
Old 03-21-2009
Fstbttms's Avatar
Originally Posted by KeelHaulin View Post
Vivid is closer to an ablative than a hard anti-fouling...
+1 (plus obligatory extra stuff since you can't post just "+1" )
Old 03-21-2009
rperret's Avatar
rperret is on a distinguished road
yes.
i used vivid white on my bottom...PO had used it and I just kept it for now.
just using 0000 steel wool will remove the coating on vivid.
the best smoothness with vivid is to make sure you have a well prepared smooth surface, then use a foam roller. its about the best you can get with that paint.
Rick
The beat goes on, the beat goes on...
The grocery stores the super mart, uh huh
Little girls still break their hearts, uh huh
And men still keep on marching off to war
Electrically they keep a baseball score
Old 03-22-2009
mvk mvk is offline
mvk is on a distinguished road
I have had good results using Vivid. Two coats of Vivid (white) were sprayed on top of an epoxy barrier coat. The bottom was then burnished to very smooth finish by the boat yard. This yard works with a lot of race boats... and are very experienced at doing this. Prior to launching, the finish was very glossy and smooth to the touch. It looked like gelcoat but felt slightly softer. Lots of folks were amazed that it was an ablative paint.
Over the past 18 months it has been very easy to clean and is still very smooth. Just a wipe-down with a soft cloth every few weeks (and right before any major regatta) and it stays nice and white. After 18 months the paint is getting a little thin at the water line and probably needs a haul-out... but it still cleans-up very easy. This is in So Cal, so your mileage may vary.
Last year we had a great race year, so I have no complaints about the speed. True, a hard paint may be slightly faster but based on our observations last year... one slight mistake will make much more of a difference.
- Mark
Bottom Paint Questions harbin2 Gear & Maintenance 8 02-22-2009 12:09 PM
Vivid Bottom Paint Freesail99 Gear & Maintenance 30 11-01-2007 06:55 AM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
