Old 03-20-2009
newportknots is on a distinguished road
Bulkhead Strength
Hi there,
The chain plates on my New York 36 are currently bolted to a 3 inch thick fiberglass bulkhead. I'm considering mounting a diaphragm pump for head discharge behind the head using this bulkhead as a mounting location. The positioning of the pump would be 5 inches away from where the chain plate is attached.
When the chain plate is under load, would the bulkhead's strength be compromised by having holes drilled into it?
Mike
W.D. Schock New York 36
Boston
Old 03-20-2009
celenoglu's Avatar
celenoglu is on a distinguished road
The distance is not too much, you can expect negative effects. This will not occur immediately but will cause deformations during time. It will be a better idea to add some epoxy and fiberglass as a base for your pump. This way you will not drill the boat but only drill the added on epoxy - glass.
Old 03-20-2009
The bulkhead is THREE INCHES THICK. These holes will be relatively small, say under 1/4" in diameter. Drilling the four holes you'd need to mount the diaphragm pump shouldn't weaken the bulkhead significantly, especially if it is THREE INCHES THICK.
If you're really worried about it... epoxy a block of teak to the bulkhead and use screws to hold the pump to the block of teak.
Originally Posted by newportknots View Post
Hi there,
Mike
Old 03-20-2009
Thanks Dog and cenegolu.
I'll tell you what worried me: A PO had already drilled a 1" whole in the bulkhead to run an intake hose. With the amount of stress exerted on that bulkhead over time - I figured cracking was inevitable.
Dog - would I be wise to fill the old hole with thickened epoxy to restore some integrity at that point?
Boston
Old 03-20-2009
Yes, and adding a couple of layers of glass over each side wouldn't hurt either.
is the Carribean coastal sailing or offshore? troyaux Boat Review and Purchase Forum 40 02-23-2010 11:51 PM
Bulkhead Confusion RichP Sailboat Design and Construction 10 11-08-2008 03:49 PM
How does an old boat fail ? LookingForCruiser Sailboat Design and Construction 7 01-17-2008 04:59 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Goodbye bed, hello storage GoodOldBoat Gear and Maintenance Articles 0 05-14-2007 08:20 AM
