03-23-2009
1979 C&C 30 Mk I - 2QM15
Ok... So I understand why a 3 blade would be a bad idea, although I have seen them on out of the water cruisers and never really understood why some people use them. And I assumed that a folding prop (expense aside) would only be good for a few tenths of a knot at best, I just wanted some validation on that. And I'm aware of how most folding prop designs create added headaches when backing up.
But that still doesn't really address my original question, so maybe I should rephrase it, since I'm basing that on an assumption as well...
My assumption was that the OEM props that came on boats from the late 70's early 80's might not necessarily be the most efficient prop that could be used. (This may or may not be true).
But if it is true, I was wondering if there's a formula that can be used to determine the most efficient prop size and pitch for any given application based on the variables I mentioned in the first post?
