centerboard pounds and makes god awful noise! - SailNet Community
post #1 of 2 Old 03-23-2009 Thread Starter
I have a 37 irwin cc ketch with centerboard. It raises and lowers fine, but when it is in the lowered position the board seems to rise up and pound back down. It is such a bad sound we are scared to use it. it sounds like it gets to its lowest position and slams into the housing it fits in. The boat is out of the water. Today im having it lifted and lowering the board to see what things look like, but I cant imagine ill see much. Are there bushings that might be worn away, or is there supposed to be a way to lock the board into position?
Thanks!
Rhett R.
S/V Emilie Winn
spark451 is offline
post #2 of 2 Old 03-23-2009
When was the last time you checked/inspected/serviced the pivot pin on the centerboard. If never, then it is probably time to do so. Most centerboards don't have a positive lock down mechanism, due to the fact that they're supposed to kick up in the case of an impact.
sailingdog is offline
