Making Companionway Doors - Page 3 - SailNet Community
 4Likes
post #21 of 29 Old 12-05-2013
Re: Making Companionway Doors
Originally Posted by drsutton View Post
My thoughts about companionway doors made from drop boards is very straightforward. Glue up the boards, seperate by cutting down the center, attach hinges and mound. Since the drop boards already fit the opening, no other cuts need to be made.
Bill
You'll need to cut off the aft edge of the companionway frame so the new doors are free to swing out. You can't swing the doors in and out of the current existing drop board slots. Easily done with a router as long as you've clearance for the base.. a router bit in a drywall trimmer can do the job in tighter spaces.
Gluing the current boards together and cutting them will work, but properly framed doors will look a lot better. If you do glue and cut I'd suggest using splines or biscuits in the joints to beef them up.. but I'm afraid it wouldn't look all that great... (JMO)
Faster is online now
post #22 of 29 Old 12-05-2013
Asleep at the wheel
jimgo's Avatar
I had though about gluing and cutting since my current drop boards had already been fastened together by the PO. But I soon realized, much like Ron's post, that it's not that simple unless you're going to get rid of the trim piece that holds the drop boards in place. That's an option, but it will preclude you from using drop boards again. For some people, that may not be a problem. But if you want (or have plans) to sail in bigger water, the ability to add a drop board to keep water from entering the cabin can be handy. I've seen some doors, like the ones Zarcor makes, that fit into the current slot. Unfortunately, those inherently narrow the companionway a bit because of the hinges. As Ron suggested, you could trim down the wooden frame, but then you're decreasing the surface area that supports the drop boards, which I think would weaken the companionway. Not that it's a structural piece - it would just make it easier for someone to kick in the doors.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #23 of 29 Old 12-05-2013
Brewgyver's Avatar
I have nice teak-framed vision doors on lift-off hinges. The hinges are much lighter than the ones Zacor uses, but I like the setup just the way it is. I only hang them in the slip (might while on the hook, but haven't done much of that yet, still a noob ), for the day or several while I'm more or less on the boat. When I head home 40 miles (still have to work), I drop the boards and lock it up. When I bought the boat, the boards and hatch didn't even have a hasp, and I didn't feel the need to lock it until I spen a chunk of change on a Raymarine e7. Fortunately, there isn't much of a theft problem at my marina. The dock gates are locked, and even though a lot of people will hold a gate open for you if you look like you're going through, you don't hear about any real security issues. Part of that might be the fair number of liveaboards.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #24 of 29 Old 12-05-2013
Never had drop boards but how about this solution. Attach with piano hinge the new doors (maybe cut up drop boards) to hardwood baton that fits snug in the old drop board slot. Pre drill access holes in hinge to screw to backside of slot. Add drip bottom and clasp to doors Nothing is altered permanently and offers the chance to make it out of 5 bucks of ply wood to see if you like it.
Faster likes this.
Capt Len is online now
post #25 of 29 Old 12-05-2013
mitiempo's Avatar
Originally Posted by aeventyr60 View Post
The best addition was a snap on Sunbrella cover that drapes down from the sliding companion way hatch cover. For the poster who was concerned about the UV degrading his newly varnished doors, this may be the ticket.
I agree. I also have a Sunbrella cover that snaps onto the top of the aft end of the slider. It has a light batten sewn in at the bottom for weight. As I live aboard it makes it easy to open or close for ventilation or when leaving the boat. Also I can roll it up to whatever height I like and I use a small plastic spring clamp to keep it there. Often in the winter I will leave the bottom board (I have 2) in and almost close the gap with the flap. Allows for as much or as little ventilation as I want and makes it easy to come and go. When I want it totally open I just flip the whole thing onto the sliding part of the hatch.
Faster likes this.
Brian
mitiempo is online now
post #26 of 29 Old 12-05-2013
aeventyr60's Avatar
All good! I added a few sinkers (weights) to the bottom seam. Also a few snaps along the bottom holds it securely in place and adds up to a real tight fit. Usually the first board is all I need. We made a second flap out of mosquito netting for when the bugs get bad and for ventilation in the tropics.
I guess we could add an eisenglass window too...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #27 of 29 Old 08-17-2014
At my Helms 27
Just finished these about a month ago.. What a relief to not chase down companion boards.
drsutton is offline
post #28 of 29 Old 08-17-2014
We have something similar. We built a canvas door with a zipper down the middle. The sides are wood battens that fit in the board slots on either side. We hold them in place with slide bolts on top, and a pin on the bottom. We have 2 versions, canvas and flexible screening for ventilation. We use this at anchor when on board. The other nice thing about this setup is it takes up little room when stowed, as you can roll it up.
This in no way solves the offshore, keeping the water out issue, or security on a dock, but we've got hatch boards for that.
capecodda is online now
post #29 of 29 Old 08-17-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
I'm luvvin mine!
made em from 1/2" HDPE matl. sheet, saorta red woodish brown....dark teak! cutt panel to fit HUGE (36" w@ to, 30@ bott) opening. reduced by 3" on each side, to slide in DB slot. doubled w/rips of same to look like framed doors. left laps as needed. all glued up with g-flex (thick, still oozes!)
still sourcing drop hinges at decent price...see dog s.s.@$29.95 PR? I think not! getting used to them of later. might not add the lift offs
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
Screens for companionway...ideas? Siamese Gear & Maintenance 20 06-13-2007 12:27 PM
Wauquiez Hood MK I Companionway - pros and cons garymcg Boat Review and Purchase Forum 0 10-17-2006 02:53 PM
Making Landfall at Night John Kretschmer Cruising Articles 0 01-05-2003 07:00 PM
