Tips For Compound, Polish & Wax - Page 22 - SailNet Community
 30Likes
post #211 of 306 Old 03-23-2013 Thread Starter
Maine Sail's Avatar
Re: Tips For Compound, Polish & Wax
Originally Posted by LifeIsGood View Post
Hey Folks,
Can anyone offer advice on the question above? Hoping to get started today.
Thanks,
LifeIsGood
I use the 3M 05717
High Speed Rotary Polisher Backing Plates, circular polisher backing plates, high speed buffer backing plate, dewalt backing plate, makita backing
For my 3M double sided pads I use the double sided pad adapter in the link above....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #212 of 306 Old 03-29-2013
First, I want to thank you for the amazing write up you created on how to polish gel coat. One thing i wanted to ask you about it. On the compounding step, when you explain on what speeds, you say to start on 600rpm, then move it to 1000rpm for 35-40 sec, then 2kplus but under 3k. my question is how long do you run it on 2k plus and how much pressure for all the steps? Do you usually do 1 section pass on 600rpm, then 4 section passes on 1000rpmm, then the final section pass on 2k plus? thanks
Jomax is offline
post #213 of 306 Old 03-31-2013
probwhite's Avatar
MaineSail - You da man. Just bought a boat and was looking for some advice on the buffing/waxing process. I'm going to print this out, break out the wallet (ugh) and give it a whirl - pun intended. Once again, you're a wealth of info.
Pauly
I came off the rebound, started looking around,
Figured out it's time to have a little fun.
probwhite is offline
post #214 of 306 Old 03-31-2013 Thread Starter
Maine Sail's Avatar
Good quality compounds utilize a "diminishing grit" starting slow keeps it heavy and removes oxidation. Speeding it up breaks it down finer and yields a higher shine. More speed breaks it down even more.
Let the machine do the work. You will need to feel out how much time at each speed on your own for your level of oxidation. Do a couple of test squares and then you'll know. Just don't keep the pad in one spot too long or let the hull get too hot under the pad. Beyond that you really can't mess much up.
______
post #215 of 306 Old 04-10-2013
Unpaid Intern
josrulz's Avatar
Maine Sail and all, I'm getting ready to compound and wax and have read this original post many times through--thanks Maine Sail!
Quick question. Any tips for compounding right at the waterline? Our ablative paint is easy to pick up. And I'm concerned about putting tape over the bottom paint since we're not painting this year (not needed).
Any suggestions?
Thanks!
-J
1984 Sabre 34 Mk I
josrulz is offline
post #216 of 306 Old 04-10-2013 Thread Starter
Maine Sail's Avatar
Any suggestions?
Thanks!
-J
Just tape it and it will be fine.. I do it all time time...
______
post #217 of 306 Old 04-10-2013
Asleep at the wheel
jimgo's Avatar
Whoops - never mind! Just read the first sentence again - not inteded for painted hulls!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #218 of 306 Old 04-11-2013
Unpaid Intern
josrulz's Avatar
OK thanks Maine Sail. I'll give it a try. Cheers!
1984 Sabre 34 Mk I
josrulz is offline
post #219 of 306 Old 04-15-2013
Followed the directions for the second year, great results again. This year I used the Presta Chroma as well. Thank you for the informative post!
svalvasori is offline
post #220 of 306 Old 04-15-2013
Shiny!
rtawood is offline
Currently Active Users Viewing This Thread: 33 (0 members and 33 guests)
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 05-05-2012 06:02 AM
Wax or polish Jotun Gear & Maintenance 58 06-26-2009 01:54 PM
Tips For Buff, Polish & Wax Maine Sail Gear & Maintenance 0 03-24-2009 03:25 PM
What polish and wax you recommend? Giulietta Gear & Maintenance 7 09-21-2008 07:28 PM
Polish VS. Wax ddilman General Discussion (sailing related) 10 07-03-2006 04:43 PM
