Like Tree12Likes
  #71
Old 05-06-2010
Captcraig1's Avatar
Captcraig1 is on a distinguished road
Need help with using 3M Finesse It!!
Great thread! I have read through many times and am using it as a guide to restore a badly oxidized (sadly some crazing) blue hull on a '76 Mirage 24. I am using the Makita 9227 and all of the products you recommended but am having trouble with the 3M Finesse It product:
1. makes the polisher jump and hard to handle (tried rpms 1000-2000, applying various amounts of pressure on polisher - using the recommended 3M foam pad).
2. product is effectively removing swirls but is also leaving some cloudy areas of product that streak when I try removing with a microfiber cloth. Continuing to go over it with the polisher/foam pad isn't removing this.
Any extra tips you could mention about Finesse would be greatly appreciated.
CaptCraig
dinosdad likes this.
  #72
Old 05-06-2010
Maine Sail's Avatar
CaptCraig
Try the yellow wool pad. The foam pads with light compounds can get to wet and "suction" to the hull. You can also carefully edge the pad but use the 3M backer NOT the Makita one. The Makita one is very stiff and will create hot spots where you have little contact/pad area on the hull. The yellow 3M backer with velcro referenced earlier is much more flexible and will edge better. Just do be careful when edging or you can burn the gelcoat. You can also dry buff it a little more, meaning buff it until it in no longer cloudy but again be careful. Those directions were written for beginners. Finesse It II can be tricky stuff to work with so just experiment a little. This is why I recommend Presta products.. Ultra Cutting Creme on a yellow wool 3M pad will do what Finesse It does only it can often do this in only one step..
Polishing = 3M Yellow Wool # 05713
Backing Pad = 3M Hookit SBS #05717
Ultra Cutting Creme (LINK)
______
-Maine Sail / CS-36T
  #73
Old 05-06-2010
deniseO30's Avatar
Lies about her age
ok.. got the hull and boot stripe looking like new... how about the deck? Do I even want to try and make it shiny again? It's a basic creamy chalk like finish now LOL. Odays' weren't pure white btw
  #74
Old 05-17-2010
Livia's Avatar
Vagabond in Training
Livia is on a distinguished road
We did a compound, polish, glaze, wax job close to these recs and have had so many people asking about it at the boat yard. She looks gorgeous!
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
  #75
Old 05-30-2010
Maine Sail's Avatar
Originally Posted by oomfh View Post
Purchased a factory reconditioned 9227c and when I started the compounding phase today - the polisher immedately began oscillating in speed - particularly under load.
Please tell me this isn't normal.
That is not normal. Set the speed, apply the pad to hull and speed stays the same pull pad from hull speed stays the same. Yours apparently was not properly "reconditioned"..
______
  #76
Old 05-31-2010
harbin2 is on a distinguished road
I got the same buffer a month ago from Amazon. It runs at a very constant speed, at all speed settings. I had purchased two knockoffs from Harbor Freight. The price was right but both oscillated greatly in speed at the lower speed settings. I returned both. The Makita is a really nice tool - send yours back for a replacement.
  #77
Old 06-07-2010
oceanscapt is on a distinguished road
Send a message via Skype™ to oceanscapt
Well thought out and knowledgeable article. I printed it out and put it in the Maintenance manual for the crew. It should save a lot of time, especially since we're 145' and 4 decks high.
Thanks for taking the time to give us all a leg up.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
  #78
Old 06-16-2010
night0wl's Avatar
night0wl is on a distinguished road
Aren't boats that large usually painted...hence making this guide useless
S/V Jendai
Beneteau 343
  #79
Old 07-10-2010
mrybas's Avatar
mrybas is on a distinguished road
Forgive me if this has been brought up already, but has anyone used "Aqua-Buff"? I have had a few guys at the marina (the knowledgeable ones) tell me that Aqua-Buff is the only way to compound/polish.....
  #80
Old 07-19-2010
Preserved is on a distinguished road
Cleaning after waxing?
I put some effort into polishing and waxing my hull for the first time this spring. With other projects taking priority, I took an afternoon and gave the gel-coated hull an acid wash to remove stains, a quick polish with some auto polish on a foam pad followed with some 3m Finesse It, then Collinite 885 wax. For quickie job it improved the look a fair amount. And I was hoping that it would reduce the stains so next spring I can put more time into this.
One thing that I notice is that the hull (white-gelcoat) stains easier than when it was bare wax-less gelcoat. I've got the vertical grey dirty streaks under each scupper leading to the waterline and the transom has a nasty black swash where the exhaust through-hull. Very unsightly!
Did I not rub the wax out enough?
Safe cleaners to use on wax?
You may post attachments
You may edit your posts
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 05-05-2012 06:02 AM
Wax or polish Jotun Gear & Maintenance 58 06-26-2009 01:54 PM
Tips For Buff, Polish & Wax Maine Sail Gear & Maintenance 0 03-24-2009 03:25 PM
What polish and wax you recommend? Giulietta Gear & Maintenance 7 09-21-2008 07:28 PM
Polish VS. Wax ddilman General Discussion (sailing related) 10 07-03-2006 04:43 PM
SEO by vBSEO 3.6.1
