03-28-2009
Sailbot, before you go "strcking bits" and placing curses...consider that 3M would be the first ones to tell anyone DO NOT USE 5200 UNLESS IT WILL BE FOREVER. It was the wrong material to use--if it was used--on those frames.
And, you're about to make the same mistake of using the wrong materials without consulting a maker as to how to do the job right. Find the West System Epoxy web site, look at their article archive on how to properly fix fiberglass, and fix the cabin sides properly before you reseat the frames. Just gooping stuff in is likely to leave you in the same situation you started in. If their articles don't tell you exactly what you want to know, call them. They provide free technical assistance (your dime for the phone call) to anyone who asks, and they just hope you'll return the favor by buying their products. (Which are certainly competitive.)
They are both great companies, that produce top quality products and top quality support. If someone misuses them--that's not their fault.
