Transmission Maintenance? - Page 2 - SailNet Community
post #11 of 15 Old 04-13-2009
billangiep's Avatar
The cone in the transmissions are costly to replace. Make double sure your linkage is adjusted to manufactures specs. including the spring joint (very important)The spring joint if properly adjusted holds pressure on the transmission shift lever in both forward and reverse. Once the cone is engaged you don't want it to slip. It was recommended to me to NOT use muti grade oil or oil with detergent it's just to slick. I use non detergent 30 weight and change it every 150 hrs or every other engine change.
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
billangiep is offline
post #12 of 15 Old 04-13-2009
Somewhat Senior Member
mgmhead's Avatar
For what it's worth. My boat has a Volvo-Penta set-up and I use Rotella T 15-40 for the engine and Rotella T 30W for the transmission. BTW, the PO worked for Shell and was one of the developers of Rotella T, he swears it's the best product on the market. I wouldn't dare use anything else now, would I.
Regards...MGM
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #13 of 15 Old 04-13-2009
BarryL's Avatar
Hello,
IMHO, transmission oil should be changed based on hours of use, not just time. Unlike engine oil, trans oil is not subject to combustion and all the evils associated with that (soot, high temperature, shear forces, etc.). If you run your engine 200 hours a year, then maybe you should change the trans fluid yearly. However, if you only do 50 hours a year of motoring, changing the trans oil yearly would be way overkill. I would not let the same oil sit in the box for 10 years, but would change it at least every 5 years. For me personally, I usually motor between 50 and 100 hours a year and I will change the trans oil after 200 hours of use.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #14 of 15 Old 04-13-2009 Thread Starter
nk235's Avatar
Thanks Barry - By the way when are you putting your boat in? Just got mine in today.
Morgan 323
nk235 is offline
post #15 of 15 Old 04-14-2009
BarryL's Avatar
Boat Launch
Hi Nick,
I should be in about two weeks. The weather has been cold and damp, so I don't feel like I'm missing much. I don't have to do too much this year, just scrub and paint the bottom, install a new raw water impeller, fresh bird spikes on the spreaders, and wash the topsides.
Barry
Barry Lenoble
Mt. Sinai, NY
transmission question almostbroke Gear & Maintenance 10 09-17-2012 10:56 AM
Reducing Exterior Maintenance Sue & Larry Gear and Maintenance Articles 0 10-15-2003 09:00 PM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 09:00 PM
The Best Maintenance is Use Kristin Sandvik Cruising Articles 0 04-02-2001 09:00 PM
