Old 03-26-2009
matt2 is on a distinguished road
How to Add Interior Teak Hand Rails?
I am hoping someone might have experience in adding interior teak hand rails to the interior cabin top.
How do you ensure they are strong enough to withstand the strain of people swinging on them when there is a bit of weather.
Do you drill completely through the cabin top and then counter sink them and cover with fibreglass?
Old 03-26-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
The interior cabin teak hand rails on our Tartan 27' are secured by through bolting them from what is known as an 'eye brow' strip of teak on the cabin side/top. Teak bungs are used to cover the holes for the screws and bedding compound is used to keep everything outside secured to the deck.
Old 03-26-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
There are lots of ways to do this; but I would try not to put holes through the skin of the deck if possible. Best to try and minimize the amount of fasteners that penetrate the deck; to minimize leaks.
You might consider gluing/glassing down some plywood pads beneath the headliner so you can fasten wood screws into them without going through the deck. 2 heavy gauge wood screws per attachment point (between loops) would probably be enough holding power.
Old 03-26-2009
kaluvic's Avatar
kaluvic is on a distinguished road
What is the make-up/construction, of your cabin top?
Do you have a removable head liner?
James S
S/V Arctic Lady
Old 03-26-2009
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
When I did this on my Catalina 27, I "matched" the hand rails in the cabin with the ones on the cabin top.
The factory installed handrails on the cabin top were through bolted at the ends and screwed into the cabin top at each loop.
So, I got new bolts for the ends that were long enough to go through both the outside and the new inside rails.
I replaced the intermediate screws with bolts that extended through both handrails
I replaced the bungs on all the holes.
Looked and worked well.
Good luck
David
1987 CS 36 Merlin "Kyrie"
Old 03-26-2009
kaluvic's Avatar
Good luck
Excellent idea
James S
S/V Arctic Lady
Old 03-26-2009
Great idea!
Thanks, good idea.
Add Inspection Port to Existing Tank mlitzkow Gear & Maintenance 4 03-22-2008 03:06 AM
Delete add GBurton SailNet Website Technical Support 1 11-20-2007 10:32 PM
trying to add a second battery to my o-day davideureka Gear & Maintenance 37 09-01-2007 12:25 PM
Please add Reliance to Boat Builders voyagersail SailNet Website Technical Support 0 02-23-2007 10:44 PM
How to add images images to your posts and replies administrator SailNet Website Technical Support 0 02-11-2006 10:25 AM
