Old 03-26-2009
sasfish's Avatar
sasfish is on a distinguished road
davits for hans christian
Hi I was hoping someone might have some photos and or ideas for a davit set up that can hold a 310 zodiac with a 15 hp. The yacht is a Hans Christian 38 without a push pit or wind vane. I would also like to see ways you guys have set up the pulley systems.
life is a reach and then you jibe
Old 03-26-2009
kaluvic's Avatar
kaluvic is on a distinguished road
I've posted some of these pics before, so sorry to those have of you that have already seen them.
I ran my davits thru the aft deck into the floor of the lazarrette
The 4inch SS vertical pieces have a solid diaphragm inside to prevent kinking where the pass through the deck (inside nylon sleeve)
They can be rotated out of the way for heavy weather passages.
There is a take-up drum in the elbow for a 2in webbing strap.
The idea is to lift the dingy out of the water with conventional blocks/line then pass the webbing from the end of the davit where its always attached....under the dingy and the tail end into the winch drum
then crank it up until the dingy is sandwiched tight up under the davits.
davits for hans christian-davits-1.jpg   davits for hans christian-davits-6.jpg   davits for hans christian-davits-3.jpg   davits for hans christian-davits-2.jpg   davits for hans christian-davits-5.jpg
James S
S/V Arctic Lady
Old 03-27-2009
kaluvic's Avatar
Mine is a canoe stern and my dingy is also 310...out board will probably be smaller than yours.
I looked and looked for davits that fit well with the stern but didn't find any.
As you see I haven’t yet rigged them up so I cant comment on how they perform.
James S
S/V Arctic Lady
RIBs on davits orthomartin Cruising & Liveaboard Forum 6 07-03-2007 01:49 PM
Dingy davits WilliamR Gear & Maintenance 35 05-17-2007 12:28 PM
Cruising with a Hard Dingy on Davits LWinters Cruising & Liveaboard Forum 6 12-27-2006 08:32 PM
RIB on 32' davits rfortenbaugh Ericson 1 07-04-2006 06:10 PM
Dingy davits 928frenzy Gear & Maintenance 0 06-18-2002 10:35 AM
