-   -   Diesel fuel tank cleaner recommendations? (http://www.sailnet.com/forums/gear-maintenance/52928-diesel-fuel-tank-cleaner-recommendations.html)
BELLATRIX1965 03-29-2009 05:28 PM
Greetings all:
We have pumped out all the diesel fuel and have removed the tank from the boat (I think for the first time since installation in 1965!). Here's the situation:
1) The tank is monel (yeah, fancy, huh?) and in good shape.
2) The tank is a deep vee shape, to fit in the bilge of a sailboat - 41 gallons.
3) The tank has 3 baffles, and a 1-1/2 inch NPT access port at the top of two (2) of the chambers (one chamber has NO access).
4) The tank is in pretty good condition inside - just some heavy black sludge at the very bottom (only about 6 inches wide at this point).
5) I'm NOT cutting any more holes into the tank.
SO: What I am hoping to find is a good chemical / petroleum solvent to add to the tank, soak / swish, and get out the black sludge. I've read about using a Starbrite product that is basically common naptha. Anybody have any experience / feedback on a similar project? Thanks in advance for the advice!
pdqaltair 03-29-2009 06:51 PM
Consider power washing...
with a flexible lance. There are a lot of safety precautions involved, but I have much practical experience with doing this in a refinery environment. It is common to have something that needs cleaned that you just cannot reach.
This is a 2-person job. Replace the nozzle with a ~10' section (or longer) section of pressure washer hose. Connect the nozzle to the end of the hose with a steel (not malleable) coupling and a short piece (12") of sch 40 steel pipe. The short piece of pipe is to keep the snake from turning around and coming back out and is very important! stuff to hose in through one of the openings, through the baffle and into the part you cannot reach. One person holds the hose and works it around, while the other holds the trigger, ready to release it at ANY sign of trouble. The person holding the hose should were very heavy gloves. The sections you can reach can be cleaned with the normal lance.
You will need to pump the water/oil mix out as you work. Most diaphragm sump pumps are rated for oil. DO NOT use a shop vac (mist = boom).
There is also the option of a tank cleaning nozzle - I do not think you need to go that way.
Please google "pressure washer safety" for more tips. This is a standard industrial method referred to as "flex lancing."
Be careful. It is a piece of cake, if you take precaution against letting the flexible snake out of the tank under pressure. If it comes out of the tanks while powered up, someone will get cut. That is why the short piece of rigid pipe is very important. It cannot leave the tank.
