Old 03-29-2009
chacho is on a distinguished road
Transmission problem
I have Cal 36 with a Yanmar 2GM engine and a Ka2A transmission my problem is the transmission won't go into forward because the shift rod is slipping out if I manually push it in it goes into gear, but when I shift into neutral or reverse it comes out and I have to push it in again does anyone know the fix for this problem .lallegro40@yahoo.com
Old 03-29-2009
timebandit's Avatar
timebandit is on a distinguished road
Did this problem just start?
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 03-29-2009
timebandit's Avatar
It just could be out of adjustment.
Rick
Mac 25
Copernicus
Southern California
Old 03-29-2009
It has been going on for some time L thought it was a Problem with the linkage I discovered the problem today
Old 03-29-2009
It is not adjutment because I can push the shift lever in an it goes into gear. When I say in I mean toward the tranny case it is moving in and out not forward and back
Old 03-30-2009
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Do you have a cable that operates the shifter from the helm? I have one on our boat that broke. It worked in forward, but not in neutral or reverse when shifting from forward. If I shifted into neutral or reverse, the shifter stayed in forward. Replaced cable.
1967 Irwin 37 cc with exhaust problem Irwin37mkIV Irwin 5 08-02-2007 07:03 PM
Motor-sailing and Transmission Damage? vwell Gear & Maintenance 5 07-14-2007 10:58 PM
Hurth Transmission John & Heather Newport 4 01-12-2007 10:09 AM
transmission question almostbroke Gear & Maintenance 8 06-05-2004 01:06 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
