Blue Sea Panels - Page 2 - SailNet Community
post #11 of 27 Old 04-01-2009
nickmerc's Avatar
I just installed a Blue Sea panel on my boat as well. Great quality of constrction, easy to use, great customer service, and (if you are really anal) they will even print up custom labels for you. Also, before you go off an buy a 70 piece set of labels to use only one, call them. They sent me all of the "off the shelf" labels I needed for free. I bought my panel from Peter Kennedy Yacht Services - Marine Electrical Systems and got a great price. Worth checking out.
nickmerc is offline
post #12 of 27 Old 04-01-2009
I would highly recommend not using Peter Kennedy Yacht Services for anything. Here's why: LINK, LINK
To give you a photographic reason:
This is a photo of the mounting plate for the swivel arm that Peter Kennedy mounted my GPS to. The screw holes are the ones he drilled. He only drilled and tapped two of the four holes the equipment is supposed to have, and one of them was in the area where the bushing that allows it to rotate is located, as seen by the pen circle drawn on the aluminum. Very poor quality work.
This is the $40 custom masthead lamp mounting bracket he sold me.
It isn't even wide enough to have the screws for the masthead light got through it. It didn't survive the trailering trip from Annapolis to New Bedford. He had three sheet metal screws holding it to the masthead truck, that were held in by silicone. The corners and edges of the aluminum aren't rounded or smoothed off in any way, and it looks like it was cut with a hacksaw by hand. You can clearly see the silicone in the bottom-most hole on the masthead truck, and the hack job he did on drilling the holes.
sailingdog is offline
post #13 of 27 Old 04-01-2009
nickmerc's Avatar
I can't comment on his fabrication work. His shop is not set up for metal working so I assume he contracted that work out. I am curious to find out who did the work. He came reccommended to me by several other sailors around Annapolis. All I can say is the prices he charged me for all new Blue Sea components were fantastic and the wiring advice he gave was corroborated by other experienced marine electricians. He also galdly took back any extra components that I decided not to use for a full refund.
________
Amura
nickmerc is offline
post #14 of 27 Old 04-01-2009
Another happy Blue Sea panel customer here. I'm refitting and upgraded to new AC and DC panels. Just spent the evening wiring up the AC panel. As others are finding, the build quality seems nice, the instructions are great, the tech support is terrific, the website is very helpful, and the panel is very easy to work on. I lost a critical bolt and one label -- hopefully I can replace them easily. Costs $1 + shipping to get a new label.
floatsome is offline
post #15 of 27 Old 04-01-2009
His company's electrical work was equally shoddy. While he may sell the equipment at good prices, his work ethic and quality of services suck. Regardless of whether he farms out the fabrication or does it in-house, he is still responsible for the quality of the work he is being paid for.
post #16 of 27 Old 04-03-2009
nickmerc's Avatar
I agree about being responsible for sub-contractors. I want to know so I can watch out for them if I need fabrication work done. The examples of his work that I have seen are fine. So far yours is the only bad review I have come across. I would tell potential customers to do some research on thier own to make the decision.
nickmerc is offline
post #17 of 27 Old 04-03-2009
We have lots of Blue Sea components in our home built boat
Good stuff, and holding up after 5 years, and 20,000 miles.
Service from company good too
nmccubbin is offline
post #18 of 27 Old 04-04-2009
Dock
Do blue sea panels come with a cover for the back side of the panel? I am contemplating installing an AC panel in the main cabin and the back side would be in a lazarette. I need to protect the back side of the panel from accidental contact.
jhaley66 is offline
post #19 of 27 Old 04-04-2009 Thread Starter
chef2sail's Avatar
They do come with a back of the panel cover
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #20 of 27 Old 04-04-2009
I believe the back cover is optional, and has to be bought separately.
Battery Setup: Blue Sea ACR? SEMIJim Gear & Maintenance 25 09-10-2008 10:49 AM
seriesdrogue or sea anchor seajoy Cruising & Liveaboard Forum 64 09-05-2008 05:37 PM
Chesapeake watermen fear blue crab not coming back Freesail99 General Discussion (sailing related) 20 07-17-2008 11:18 AM
Blue Sea Systems JT1019 Gear & Maintenance 0 09-08-2006 11:39 AM
