Old 03-30-2009
dreamalbin is on a distinguished road
head, toilet and holding tank for ballad
Hi folks, We are in the process of installing a new head / toilet (manual) in an Albin Ballad 30', the holding tank is above the toilet and the sliding sink is in between. The boat is in Florida and I am in Canada working (to pay for it ).
The folks installing the seat are not sure how to route the plumbing and suggested eliminating the sink (which I turned down). Is there anyone out there that has a diagram for this layout? ideally, I would like to know if the tank above the toilet is stock/original, this one is a stainless steel, and if anyone can post pictures if they do have the same set up in an albin.
Thanks in advance. Cheers, Edgard
Old 03-31-2009
Cruisingdad's Avatar
Best Looking Moderator
Going to move this into Gear and Maintencance Forum. Maybe you will get more response.
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 03-31-2009
CaptainForce's Avatar
Dreamalbin, I'll bypass the photos or diagram, but I think I can write your way through the most efficient functional plan. Influent water for the head would enter at a through-hull with a seacock or ball valve near the head to provide water for flushing. The effluent hose from the head, typically 1 1/2" would lead to the top of the holding tank. The top of this holding tank would also require a fitting to attach a vent hose. The preferred run for the vent is to loop it well above the waterline but to have it exit low and aft so odors won't waft across the cockpit or deck hatches when air is expelled from the tank. The 1 1/2" hose removing material from the bottom of the tank is best lead to a "T" fitting close to the tank (no Y-valve is required here or in this entire simple system). One effluent from the "T" leads to a deck fitting for pump out and the other effluent from the "T" leads to a macerator pump equal to the base of the holding tank. A higher placed macerator may have priming problems and too low makes repair a big risk of mess. The best choice is to have enough hose to detach the macerator and raise it higher than the tank contents for repair. The effluent from this macerator would then lead to a through-hull. No Y-valve is needed for this system because, during pump-out, material is not pulled backwards through the macerator and all suction is applied to the tank and when the deck pump out is closed all suction is applied to the holding tank by the macerator. Regulations in US waters will require that the effulent seacock or ball-valve from the macerator is locked in a closed position or that the access to this closed valve is locked. An added avantage of this system is, if your macerator ever lacks function due to an air lock and lack of priming that can occur after rolling in rough seas; then, a simple cure is to pour a little water into the deck pump-out fitting. 'take care and joy, Aythya crew
Old 03-31-2009
Brian, thank you for assisting me and moving the thread over. I realized it was not the appropriate forum only after submission.
Captain Force, I appreciate the detailed write up. I will follow through with a drawn plan and try visualizing the system you are suggesting. I will also post questions and pictures during and after completion.
Cheers, folks and yes I will go and introduce myself in the appropriate corner
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 08:00 PM
Pump it Out Joy Smith Gear and Maintenance Articles 0 05-08-2003 08:00 PM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
Head Maintenance Blues Tom Wood Gear and Maintenance Articles 0 11-21-1999 07:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 07:00 PM
