04-01-2009
The charger is discounted to $35.00 so not much of a financial risk. If the panel puts out an occasional 18VDC instead of 12, perhaps adding some sort of mini voltage regular would be easier than using a storage battery?
I found one here for $13.00:
The RG12 Inline Voltage Regulator delivers true, stable and filtered 12vdc voltage with capacity up to 850mA of current draw. If offers a cost effective solution for powering many of our LED products from higher DC voltages such as marine, automotive, recreational and power sports vehicles, solar products, lead acid 12v batteries and Class 2 type transformers (AC to DC adapters) which all produce unstable voltages from 13.5 to 17 VDC. Most 5mm LED products require a true 12.0V DC regulated power supply and therefore, these unstable voltages will damage the LEDs and cause failure.
