Anyone have a toilet recomendation? - Page 2 - SailNet Community
post #11 of 18 Old 04-03-2009
Somewhat Senior Member
mgmhead's Avatar
Buy cheap...replace often. Never rebuild!!! I hate changing out a joker valve.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #12 of 18 Old 04-03-2009
For manual heads, the Lavac and the Raritan PHC/PHII are basically the top rated by Peggie Hall, diva of marine head systems.
sailingdog is offline
post #13 of 18 Old 04-04-2009 Thread Starter
jarcher's Avatar
I'll spend a lot of time this weekend scraping, but also measuring windows, vents, GPS mounting location and head area. Then I'll spend a good chunk of time this week researching and placing orders. If I'm lucky I'll be able to get to useful work next weekend.
So many projects, so little time...
jarcher is offline
post #14 of 18 Old 04-04-2009
Valiente's Avatar
I've mentioned this before, but for what it's worth, the deal was sealed in 2006 when we bought our current boat the second my wife saw the Lavac (I had no idea she could recognize one). She said "Oh, yeah, the head you can flush a pair of jeans down. I like this boat."
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
post #15 of 18 Old 04-05-2009 Thread Starter
jarcher's Avatar
Well the bad news is that for the Lavac, there is nowhere to mount the pump. But the good news is that it is virtually the same size as whats there now, and there is plenty of room behind it to build up a back wall with some recessed shelving to the left and the pump mounted to the right. That should actually be quite easy.
The head is port side forward, so the right side is less deep then the left side. I'll have room to run the hose up for a vent loop and mount the pump to the right, and make some recessed storage cubbies to the left.
There are two sea cocks right below the head. I'll have to decide if they stay or go. I guess for now they stay. I'll keep using the inlet, although I would prefer to share with the engine water inlet. I'll seal up the outlet and hopefully it won't sink my boat someday
At least the planning is moving along!
jarcher is offline
post #16 of 18 Old 04-05-2009
Shortman's Avatar
Phii
In the 4 years I have had it I am very happy. Has a great reputation & for your use would be fine. I've heard pretty much all good about the Lavac & the attraction to me on the Lavac would be less water use, fill tank slower. Just like with anything else, maintenance, maintenance. Give it about an hour every spring, new joker valve (for the standard units like PHII), grease etc.
Shortman is offline
post #17 of 18 Old 04-05-2009
I just bought a Raritan PHII from Sailnet. It was about $270 with freight and tax, had it the next day. Try pricing them here, if you have problems with Sailnet's site go to marine.com( same company), it has a better search engine.
denby is offline
post #18 of 18 Old 04-05-2009
I just wanted to put is my two cents about the raritan PHII, I'm just installing a service kit in ours. Now that I have it all apart I can say that it is well designed, simple to maintain or repair, and ours seems to have lasted very well. Ours is older than 15 years and I'm only putting the new kit in so I don;t have to worry about it when we're offshore. I would highly recommend it.
Newport41 is offline
head, toilet and holding tank for ballad dreamalbin Gear & Maintenance 3 04-01-2009 12:22 AM
Maintenance Free Toilet CaptainTomas08 Introduce Yourself 5 11-22-2008 04:20 PM
Toilet problems.......... Perithead Gear & Maintenance 31 02-07-2008 06:20 PM
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 09:00 PM
Toilet Ethan_nyc Gear & Maintenance 1 07-10-2001 03:10 PM
